Hi i have a problem with my lcd screen.i have not use him for a long time (1 year) and now i use it on my new computer,after i connected all the wires i tried to open it and it showed me not optimal resolution ,recomanded 1024x768.Ans then the screens goes black I used another screen to switch it to 1024x768 or lower and try again the screen with the problem and its still not working. Please can you help me(Sorry for my BAD english )
    Master:
  • 497 Answers
Ok.. Since you gave me no valid information reguarding Manufacturer Names, Make and Model Numbers of the devices that you are referring to, I cannot get entirely specific on my suggestions to you.. But I can tell you this.. On BOTH DEVICES, (i.e. New Computer/LCD Monitor), go to the Manufaturer's Support Website and check for Current Updates per Operating System as well as Device Models.. ok?
Posted on Sep 12, 2010
Osd locked fujitsu
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 19, 2014 | Fujitsu Siemens Siemens Basic Line B17-1...
Lcd screen doesnt work
check lcd connection & clean.if ok flash software.
May 30, 2012 | Canon PowerShot SX20 IS Digital Camera
My laptop wont show screen display
Losing the display on a laptop or notebook computer is a perplexing and frustrating problem. It's a problem that is somewhat difficult to diagnose, and can require specialized tools and a considerable financial outlay to repair. When the display on a laptop computer stops working, the computer is usually not worth the investment to repair.
1.Diagnose the problem with your computer. Watch the screen from the moment you hit the power button through the time it should take to boot into the Operating System.
Adjust the computer's contrast and brightness through their full ranges to make sure that the display settings have not been changed.
Reset the computer's LCD-External Monitor display with the LCD/External Monitor key combination and reboot the computer.
Continue to Step 2 if the screen is blank throughout the booting process.
2.Adjust the screen from its fully closed position to its fully opened position. Watch the monitor for any change from a blank screen to a display or vice-versa. If the screen flashes or cuts out, the LCD panel will need to be replaced. Skip to Step 5.
3.Skip this step if your computer does not have an external monitor output.
Connect your computer's external monitor output to a known good monitor and change the display from LCD to External Monitor (the keystroke combination is different for all notebook brands). Reboot the comptuer, if necessary.
If the computer does not display to the external monitor, the video card could be bad. Skip to Step 6.
4.Consult with a professional technician to determine the cost-effectiveness of replacing your computer's LCD if you are not knowledgeable in that area.
Purchase a compatible replacement LCD and install it yourself, or pay a professional technician to do so if you do not feel comfortable performing the repair.
5.Verify that the monitor connection cables are not loose or disconnected before attempting to replace it.
Replace the monitor yourself by removing the old monitor. Remove the hinge covers by gently prying them. Check if they are screwed to the computer before prying.
Find the monitor cable's connection to the motherboard. Turn your computer over and remove any plates that may cover the point of connection. Note the orientation of the cables before disconnecting them.
Unscrew the monitor from the hinges and gently detach it from your computer. Feed the new LCD panel's wires through the same path as the old wires, and reconnect them. Secure the new LCD's hinges and replace the hinge covers.
Power up the computer and check that it works. If it does not, recheck the wire connections.
6.Consult with a professional technician to determine the cost-effectiveness of replacing your computer's motherboard or video card if you are not knowledgeable in that area.
Purchase a compatible replacement motherboard or video card, and install yourself or pay a professional technician to do so if you do not feel comfortable performing the repair.
7.Replace the motherboard by disassembling the computer. Document every connection and be sure to retain all screws and small parts in order to reassemble the computer correctly. Reassemble the computer and power it up; check the keyboard to make sure that it has been reconnected properly.
Replace the video card by removing any covers or plates that hide the card. Remove the old card and install the new card in its place. Power up the computer to test the display.
Sep 09, 2011 | Computers & Internet
HI, i have sony vaio laptop. few months ago i face the problem that my computer LCD light. after starting 2 or 3 times it show the screen. it is running every time. i can see dim screen but after 3 or 4...
In your situation, you have the possibility of several different problems.
1. Your "Screen Inverter" is failing.
2. Your screen "LCD Panel" is failing
3. The "Video Controller Chip" soldered permanently to your motherboard is failing.
The first step in troubleshooting these problems would be to take your laptop to a friend's house who is using a desktop computer with a separate external monitor. Hook your laptop up to the external monitor and see if it displays normally on that monitor. If it does, you merely need to replace both the Screen Inverter and LCD Panel of your laptop and you'll be fine.
If, however, your laptop will not display on an exterior monitor, it means that your video controller on your motherboard has failed and you'll have to either get a new motherboard installed or consider replacing your laptop.
I'll be rooting for # 1 or 2.
Kind Regards,
Selk
Apr 29, 2011 | Sony VAIO Notebook
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Lcd tv screen shadow
they call that line pixels and the only way to fix is a new lcd panel. if you have under 8 pixels your warrinty won!t cover with some companys
Aug 31, 2008 | Sylvania 6427TE 27" TV
LG lcd computer monitor
try to connect your old monitor and adjust your screen properties down to 800x600 with medium color setting..or go to xp safe mode, adjust screen properties to the lowest setting, xp has not yet installed the monitor driver of your lg lcd monitor.
May 21, 2008 | Gateway FPD2275W LCD Monitor
The bottom of the screen has become darker!
Hi
The symptom you are telling is similar to FL inverter problem but with that case usually entire screen goes dim. You may try to reset the settings (Usually AUTO button). Unplug and plug in the electrical connection+Computer connection. Also make sure your Display setting in computer side has not been modified. If issue persist take to the qualified service center. FL inverter is the illuminator part of LCD works like fluorescent tube. FL inverter issue rather lower cost compare to other LCD issues.
Good Luck Happy New Year
Dec 28, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
