Question about GPS
X-gps s500a In trying to put in an address & 'set as a destination' an error message comes up "cannot find path maps are isolated'. The gps came preloaded and has a DVD - probably for Backup. Can you help?
  • 3 Answers
SOURCE: GPS reception
Navman in no longer offering map support for it's iCN 510. This means if there is a new road or community, this unit will not recognize it.
I am really mad about this. I spent $400 2 years ago for something that will not have anymore map updates. Here is there reply when I wrote to them about it. Class action suit anyone?
Dear Henry,
Thank you for contacting Navman Technical Support.
We do apologize for the inconvenience. Navman has decided not to release further map updates for these device due to changes in technology over the last year. We have changed the chipset1.gif and software1.gif platform and are unable to update this device. The Navman 500 series was released with an updated map version last 2005.
If you need further assistance, please do not hesitate to contact us, we'll be more than happy to help.
Kind regards,
Ofelia
Technical Support Team
Navman USA
C/O Mio Technology USA Ltd.
47988 Fremont Blvd.
Fremont, CA 94538
Office: +1 (866) 962-8626
www.navman.com
Posted on Mar 14, 2008
sharcnet
  • 2130 Answers
SOURCE: "No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Posted on Dec 13, 2008
  • 20 Answers
SOURCE: Backup Streetpilot C330
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Posted on Jan 20, 2009
SOURCE: Webupdater won't detect Garmin unit
I have the same problem of the Nuvi 850 being recognized by webupdater. I downloaded 4.30 firmware update using this link http://www8.garmin.com/support/download_details.jsp?id=4043 plug the unit in and ran the update. It will ask you to disconnect once it is done. The unit will boot up after a few update progress bars. Plug it back in and launch webupdater.
Enjoy,
Fellow 850 owner.
Posted on Mar 26, 2009
  • 31 Answers
SOURCE: garmin auto gps c330 freezes
"Black Screen"
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
How to downlpoad navigation path
really need your question to have more info.about what your trying to do. if you put in your home address and then go to navigate and type in your destination as it ask you to do, then the gps will automatically navigate you to that destination.
Jan 03, 2015 | GPS
Avic s1
hello sir,
Portable Smart GPS Navigation comes with 3.5-inch Touch Panel Display, 2GB Flash Memory, Bluetooth Wireless Technology, and Scroll Wheel
  • 2GB Flash Memory contains the map data of entire US and Canada
  • Just unpack and use it � no PC connection is needed for startup
  • Future map data updates will be available by SD card � just load into the built-in SD card slot and the update will begin
  • Quickly set a destination by address, zip code, destination history, and more
  • Search for a gas station, restaurant or coffee shop using the POI Search � destinations are sorted into categories for short-cut searches, or use the touch screen to type in the name.
thanks for allowing us to help you
Dec 30, 2007 | Pioneer AVIC-S1 GPS Receiver
Whenever i put in the address from which i am leaving to go to a destination it wont do anything and also in the car it wont show me the road that i am on
When the GPS device starts up ( when you power it on ), it will take several seconds, up to a couple of minutes to locate the satellites, before it will show where you are (on the road / map). So, you simply have to enter the destination address, to get directions from where you are, to the destination.
It is easier for the GPS device to locate the satellites if the GPS / you are not under (some) cover, e.g. indoor garage, under ground parking, under trees, etc. Some times you'll just have to wait a little longer. [But you can enter the destination addresses even before it locates your position ]
Feb 13, 2011 | MyGuide MG 3100 Car GPS Receiver
It won't accept the address I'm going to only part of the house numbers
Some GPS maps have incomplete records of the the numbers of the streets. In other words, let's say you're looking for 732 Main Street. The GPS map may only have Main Street number houses up to 500 and it will not allow you to enter any higher house number. This is fairly common with many GPS, regardless of make.
Your best options are:
1) Set up the address you are going to the closest one that your GPS will allow. In the above example, set the GPS to take you to 500 Main Street. You'll be about 2 blocks from your destination, so you should be able to find your destination without any problems.
2) If your GPS map is more than 3 years old, you MAY benefit from an updated map, but as I mentioned above, this type of errors is relatively common with most GPS and updating to a newer map many not solve the problem.
Hope this helps. If it doesn, please report back so that I can be of further assistance.
Mar 29, 2010 | Alpine PND-K3 Handheld GPS Receiver
Was just given a TomTom and car adappter to use on my trip from MI to MD. I've never used a GPS and no manual was included how to program it from start to final destination
The TomTom only needs for you to enter your destination address. Once that's in, you're ready to go. Along your route you can tap the center of the screen to find POINTS OF INTEREST such as FOOD, LODGING, etc...but will retain destination info 'til either cleared or changed to new destination.
To enter your destination, tap center of screen. There you choose house address, business address or city's center. If you choose street address screen opens to:keyboard. Type in destination State, ie; Maryland. Once you've typed state, hit DONE in bottom right corner. The screen then goes to CITY. Type in destination city then hit done again. Follow the same steps for STREET NAME & HOUSE #. Click DONE & CONTINUE as prompted. TomTom will then target your location and you're ready to hit the road. It will show you your distance and time (ETA). It will also show you the speed limit where you are and the actual speed you are going.
When you pull over for gas, food, lodging, shopping, sight-seeing or whatever, it will automatically account for this and will continuously update your coordinates to get you back to the highway/road you need to be on. And when you're ready to come back to MI all you have to do is hit the home icon and it will automatically map your trip back.(Home is - or should be - set to the home address of the owner of the GPS).
All-in-All it is user friendly and very simple to use.
If you need additional info, please don't hesitate to ask.
I hope this info was helpful to you. Good Luck!
Have a great trip and drive safely. :-)
Jan 31, 2010 | Tomtom XL 340S Car GPS Receiver
Once I type in the address and hit OK the address
what brand of GPS what maps Polstar, Destinator ....?
Sep 03, 2009 | GPS
No map of ireland
Yes that model does have maps for Great Britain and the Republic of Ireland. As long as it's a newer model you are good to go (which it sounds like it is).
The easiest way to check would be to put in an address in Ireland as the destination. If it gives you an error saying not found then it's a safe bet that it does not include a map of Ireland, if it says impossible to navigate from here then you know it does see the destination, and knows that you can't possible get there by land from where you are.
Jul 08, 2009 | Tomtom ONE GPS Receiver
Error during planning
The most usual reason for this is a corrupted map. Try reloading the map. This certainly worked for me.
Apr 06, 2008 | Tomtom One Europe v2 GPS Receiver
GPS Logo
529 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
