Question about Dishwashers
Not wahsing properly, leaves "grit"on dishes, particularly the top shelf. can put a cleaner through, will be ok for a few cycles then it starts again. i hate it, about to buy a new one - a different brand!
  • 1,525 Answers
Hello this may be down to the top arm not moving around properly i'e somethink blocking it make sure when you reload it in the basket level good luck
regards
shaun
Posted on Sep 12, 2010
Brada EF6304SS dishwasher leaving grit and dirt on dishes
The fine grain is part of you detergent, change detergent and do not use so much
Feb 05, 2016 | Dishwashers
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
Dishes not washed properly. Have tried universal plus at 65deg, the water does not seem to get hot until it is in the main wash cycle. Used to use the universal cycle at 55deg with no problems. Also the...
Hi
Thanks for using FixYa. Check the water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible.
This would have happened as the dishwasher was overloaded with more than prescribed number of dishes. Check the spray arm and pump cover for splits or leaks. As the dishwasher is not draining properly, this issue is related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | Miele 24 in. G656SCi Plus SS Built-in...
After cycle, there is grit on my dishes
sometimes I have found if the arms are not freely going around then this can leave grit or if you have run out of rinse aide..the filters are usually in the bottom of the machine..hope this helps
Apr 16, 2009 | Dishwashers
Dishes do not come out clean?
is the salt container cap damaged or loose? is the rinse aid topped up? if all ok then are you scraping most of the food from the plates, this can cause old food to mush, pulp and leave grit on dishes.
Mar 18, 2009 | LG LDF6810ST Stainless Steel Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishwasher overflowed out of d/w during wash cycle; not draining
2 things to check
First turn off the power(breaker box to dishwasher and sdisposal
open the doors to your sink and and check the hose for any kinks etc
open the dishwasher door, bail out water remove the spinning hub and see if you can remove
the strainer and bail out more water
you can use a baster to **** out more to view
to see if the pump area is plugged
reverse proedure and turn on dw
listen to see if the pump engages on that cycle
hopefully this solves problem
If the pump does not engage you wil need to call for service
Jan 01, 2009 | Mx Commercial Line Drano Max Clog Remover
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher
basic checks:
is water entering into the machine.
is it hot.
is it being heated during pre-wash
is the soap being dispensed
is the pump running when cycling?
do the arms turn freely?
you mentioned the top and bottom shelves. are there places where the dishes 'are' being cleaned?, or are you meaning that in general they are not being cleaned at all?
most of the above indicators are observable by stopping the wash cycle from time to time in various modes.
to see if water is being pumped at all, put a bowl on the top and bottom shelf, and nothing else. if there is water in it after it cycles then the pump is moving at least some water.
start with these observations and please report back
good luck
mark
Dec 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
Owen Barnes
