Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
No display I have a similar problem however when the monitor is powered on the power light turns green and changes to orange right away. I never see the backlight flash or any other indication on the monitor. I have a couple of other monitors that had the backlight problem. Those can be fixed with between 3 and 5 capacitors on the backlight board. Thanks in advance, Terry
With the monitor hooked up and the computer on, you can take a bright flashlight and shine it on the screen and see if it is displaying a picture. If you can see a picture then you can go the route of fixing your back light. I have a spot light that I use and it works really well. If you can't see anything then you are probably SOL and have to replace the monitor.
Posted on May 16, 2008
Why has my monitor turned orange. model dylm19r6 computer monitor
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jul 14, 2014 | Soyo Computers & Internet
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Power problem????
Your Secondary Power supply Hot TRansistor is Faulty, Its situated next to the lopt TRansformer to a Heatsink
May 16, 2009 | NEC MultiSync LCD1770V - Flat panel...
Monitor shuts off after inactivity
Hi maggieis,
I wouldn't worry about your monitor powering off after 30 min. It's just responding to the power management settings that are configured from within Windows.
These settings can be changed so that your monitor always stays on (if you want) but the current setting is set to help save energy by turning off the monitor when no one is using the computer.
So, no worries...that's just normal Windows behavior.
Hope that helps,
Michael
Nov 19, 2008 | Westinghouse LCM-19v1 Monitor
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
