Question about Car Audio & Video
Chrysler infinity 33670 amp speakers i need to know the what the four wires go to so i can install them
  • 14 Answers
SOURCE: Rear deck speaker install
I'm assuming that you have left the original wiring intact? If this is the case then it's a pretty simple thing to do. There should only be 2 cables one for each speaker & each cable will have a positive & negative polarity. Once you have securely fixed the speakers into place (usually screwing into place through the mounting holes provided) you just need to attach the wires to the speakers. If your car has manufacturers plugs on & don't match the speaker ones (quite often the case now) simply cut them off & replace with spade connectors of the right type/size. The most important thing is to get the polarity the same way round for both speakers!If you get them reversed you will NOT get any bass. Also remember with any new speakers they need time to run in & sound their best....so take it easy with the volume control for the first 20hrs or so of play if you want them to sound great & last longer!
Posted on Dec 28, 2007
  • 112 Answers
SOURCE: how to install infinity kappa
If you can give me more info should be able to help ,what rms wattage is the amp and speaker is it a subwoofer or pair of speakers.
Posted on Apr 20, 2008
wdwbusiness1
  • 4 Answers
SOURCE: car stereo installation speakers
Yeah, rewire that.
Posted on Aug 19, 2008
SOURCE: need wiring diagram 94 jeep with infinity sys and amp
http://www.jeepforum.com/forum/showthread.php?t=507916
has the wire harness information for the amp. very hard to find great photos. the radio should have the sticker on the back telling you what the wires are designated for.
Posted on May 16, 2009
  • 45 Answers
SOURCE: I have a 2002 Chevrolet Camaro with the Monsoon
one of those wires on your speakers is the common ground for both sets of wires in your camaro, Just take the negative wire from both sets of wires and run it to the single wire on your new speakers. The other 2 are positive from each wire. good luck
Posted on May 25, 2010
1999 dodge grand caravan with The stock Chrysler/Infinity sound system
You can use the amps if your replacement speakers have the same or higher resistance as compared to the original speakers.
Sep 02, 2017 | 1999 Dodge Grand Caravan
It's not really a problem. I just need to know the color coding of the factory amp to my friends1999 Jeep Grand Cherokee Laredo. Basically he was so impatient that he had this kid just snip wires not...
I would try to find out who manufactured the amp and try get info from them. If not try searching more on the internet. If it is in a Chrysler or jeep good chance it may be manufactured by infinity.
Jul 11, 2010 | 1999 Jeep Grand Cherokee
I have a 2002 Chevrolet Camaro with the Monsoon stereo system, The front speakers take four wires. The Infinity Kappa 62.7i were the perfect speaker, but they stopped making them. I do not want to put...
May 24, 2010 | Infinity KAPPA 62.9I Car Component System
How can i get the factory infinity amp to turn on
the best way is to get the schematic for your specific car. that will tell you what you need (your looking for the remote/switch on wire. once you have the schematic ,if you need help reading it you can hit me up and i can help (i am a tech.) hit me up at ohmega1080@yahoo.com
Jun 21, 2009 | Car Audio & Video
Can I use a Chrysler/Infinity amp with aftermarker JVC radio?
it wouldn't be advised unless there are rca connections into the amp. these are the same as the inputs in the back of the jvc. It is possible to connect into an amplifier using speaker cable but i wouldn;t advise doing this unless you know what your doing.
May 15, 2009 | Kenwood KDC-MP235 CD Player
Volume low on all four speakers, some static (amp or head unit problem)
I would check the amp first, especially if you have very low sound on the speakers. Before amps were made, bad output transistors would create the same effect.
Apr 13, 2009 | 1997 Chrysler Sebring
Jeep cherokee infinity amplifier
yes, you have a few options. Chances are, its your amp.
1st I would test the speakers - find the amp under the back seat, then test which wires go to the front speakers and use a AA battery to check if the speaker pops with those two wires and the battery.  If it does pop, its your amp needing replaced.  You can switch out that infinity amp for an aftermarket one very easy. Just use a testlight, or voltmeter to test the wires, and switch them to a new 4-channel amp.
if you need the wiring diagram, let me know...and dont forget to rate me! or ask for more help!
Sep 04, 2008 | Car Audio & Video
Chrysler Pacifica Aftermarket Radio Problems
Here is the solution:
Their is a chrysler amplifier some where in your pacifica.In order for your signal to reach the speakers you need to buy a box (from bestbuy install ,or any car stereo install place)that allows the signal to "pass thru"to the speakers.
Nov 22, 2007 | Car Audio & Video
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
