Question about Maytag Dryers
I have a Maytag Heavy Duty Quiet Series 200 Dryer, and when I turn the dryer on is makes a horrible screeching sound. Like metal grinding against metal. What do I do?
I also have that horrible screaching sound!!!!!!
Posted on Sep 02, 2014
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 55 Answers
That's easy, first of all you must have the Dryer on flat floor I mean verticly right. And try not to put too many clothes to get dried.
Posted on Sep 12, 2010
  • Jeff T Nov 13, 2011
    ^^^Really? Not very helpful at all. I too have the same problem maria_d1995 and ours sits level. Any help out there?
I have a Maytag Heavy Duty /supersize capacity/Quiet Series 100/ 10 cycle dryer. It is not so Quiet when it is turned on, It has a very loud squeak for about 5-10 min. Then it quits and does not have A...
my daughter had same problem. maytag used to be build to last but no more. the dryer tub sits on the front lip around the door opening the support breaks and then the tub has no support and ride around rubbing on opening lip squeeking and causes a lot of friction and will either break the belt or a plastic piece on the motor. it broke all the above on my daughters dryer. we just junked it good luck
Sep 10, 2012 | Dryers
I have a quiet series 200 Maytag dryer. The dryer comes on but the drum does not turn?
Sounds like your belt broke. Here is a video to show you how to replace it if it is broken.
Here is a link to the part.
Nov 30, 2010 | Maytag PYE2300AY Electric Dryer
Grinding noise.
Typically, on the Maytag Neptune dryers, it is the felt gasket that is the cause and source of the noise you're hearing.
There is a felt gasket that runs all around the front and rear of the dryer drum and cabinet door edge (on the backside lip). As the dryer ages, this felt wears out and needs to be replaced to prevent the awful screeching sounds you'll experience, once the metal to metal contact becomes constant.
You can view the parts that need replacing at the following link (Item #14 on the drawing)
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDG5500AWW&productCategoryId=0151200&brandId=3048&brandDescription=MAYTAG&modelName=RESIDENTIAL-DRYER&diagramPageId=00006&componentDescription=TUMBLER&documentId=M0608072&blt=06
This was a fairly common problem with the Neptune line. You can see for yourself by simply turning the drum with your hand and feeling and listening for the rubbing/grinding noise, along the top of the door opening.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
899 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
