Question about Ryobi Saws
I have ryobi hj-500p jig saw. lost the manual and would like to change the blade
5 Suggested Answers
joboo1
  • 257 Answers
SOURCE: Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Posted on Mar 08, 2009
SOURCE: Instruction manual for Bosch Jig Saw 1587AVS
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Posted on Jun 24, 2009
rowdy45176
  • 2176 Answers
SOURCE: change blade 1587 Bosch avs
are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Posted on Oct 10, 2009
SOURCE: task-force-4-amp-jig-saw
how do i change blade on task force jig saw. i am un able to pull it out after pressing button for it
Posted on Jul 01, 2010
What type of blade do I need for a jigsaw ryobi js500qeo
Any type of jig saw blade will work, the are universal....
Feb 25, 2015 | Ryobi Saws
I need a manual for CJ500 jig saw. I can't work out how to change the blade.
Ryobi has a customer support questionnaire that you can fill in to ask a question http://ryobi.custhelp.com/app/support/ask/incidents.c$enquiry_type/11
I suggest that because their database of instruction manuals seems to be having problems. I did find a picture of one of those saws and it appears that there are 2 hex screws that hold the blade in. it's the hex caps in FRONT of the top of the blade. Loosen those hex cap screws and the old blade should fall out.
Jan 16, 2015 | Saws
How do I change blade on Ryobi compact saw please
Which exact saw are you talking about? Jig saw, circular saw, plug-in, or battery? It does make a difference, you know...
Jan 07, 2015 | Ryobi Garden
Extracting broken blade not sticking out of blade holder
Spray with WD 40 and insert Needle nosed pliers to grab and pull it.
Nov 30, 2013 | Ryobi Js550l Jig Saws
How do you change a blade on a Skil 4280 jig saw?
It is REALLY easy, when you know how. There is a black piece, the larger one, near blade insert...lift it and VOILA, you can insert or remove blade easily. I lost manual and spent forever trying to put blade in. Hope this helps.
Sep 22, 2013 | Skil 4280-01 4280 Variable Speed Jigsaw...
Trying to change blade in Ryobi P520 Jigsaw
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Nov 02, 2010 | Ryobi 18 V Orbital Jig Saw P520
How do I change the blade on a Black & Decker JS500 jig saw?
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
Oct 03, 2009 | Black & Decker Scroll Jig Saw Blade
Task-force-4-amp-jig-saw
Aug 04, 2009 | Saws
Saws Logo
329 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
