Question about Microsoft Office 2007 Basic for PC
Font wwhi0101.ttf require - Microsoft Office 2007 Basic for PC
Posted on Jun 16, 2013
Download shivaji fonts
Go on Google, type in the font name you want and download and install the .ttf (True-Type Font) file. Then you should be able to use the newly installed font in any application installed on your computer.
Apr 30, 2014 | Computers & Internet
Tip
HOW TO CHANGE FONTS OF N73
HI BUDDIES,
TODAY I AM GOING TO TELL YOU A GREAT TIP ON HOW TO CHANGE FONTS OF N73.FOR THIS YOU NEED 4 THINGS
1)A SOFTWARE CALLED SECMAN(DOWNLOAD IT FROM usefullsoftz.xtgem.com)
2)Y FILE VIEWER(usefullsoftz.xtgem.com)
3)FONT ROUTER.INI FILE(usefullsoftz.xtgem.com)
4)FONTS
A) FIRST OF ALL TAKE A FONT FILE ANT MEKE ITS 4 COPIES IN PC NAMED AS
NOSNR60.TTF
NSSB60.TTF
NSTSB60.TTF
S60ZDIGI.TTF
AND TRANSFER THEM TO UR PHONE
B)INSTALL SECMAN IN UR PHONE AND LAUNCH IT.WHEN LAUNCH IT,IT WILL RESTART UR PHONE.DONT WORRY ITS NORMAL.AFTER THIS AGAIN LAUNCH SECMAN AND PRESS OPTIONS AND CLICK ON
"TURN SYSTEM CAPS OFF"
C)NOW INSTALL Y FILE VIEWER.NOW LAUNCH IT AND OPEN C DRIVE THEN SYSTEM FOLDER,THEN RESOURCE FOLDER AND THERE U WILL SEE A FOLDER NAMED AS "Fonts"(if not then create it)
D)IN FONTS FOLDER COPY PASTE THE FONT ROUTER FILE AND FONT FILES AND EXIT THE Y FILE VIEWER
RESTART UR PHONE AND SEE THE CHANGED FONTS
ENJOY
on Apr 14, 2010 | Nokia N73 Cellular Phone
Font won't unbold
Is this for a TTF True Type Font or some other font format?
Assuming you're running Windows, it all depends on which operating system you're running. Typically PCs use True Type Fonts (TTF files), which are installed and stored in the Fonts folder, which is a sub-folder of the Windows folder.
Some True Type Fonts are only available in Bold, Italic, Normal and Bold Italic. Some are also available in more or less variations. Some fonts are only available in Bold, some only in Italic, etc.
You may need to check if you have the Normal font installed, and it may be the font selected is only installed in the bold version. Another possibility is your Normal font file might be damaged or corrupted to where it's no longer recognized by your system.
You can check out the Fonts folder to see if the typeface you're trying to use is installed properly in the Normal style.
If not, select another font and see if that works for you. This would be a good indication that it's simply a matter of the Normal font variation not being installed properly.
Hope this helps!
Nov 19, 2013 | Corel WordPerfect Office 11 (corwposlr)...
Britannica 2012 ultimate hangs up at folder d;\data\media2-data does not move stuck there for 3 hr anyone help with this problem running windows xp home thanks for any help
It sounds like you are trying to install some fonts, and trying to install a lot of fonts can get a little tricky. also sounds like you are transferring these from a DVD? The following should help:
first lets create a new folder on the desktop, call it something like "britannica fonts 1"now try just transferring a portion of the fonts to your desktop into the newly created folder.ok, once those have finished moving from the DVD to the desktop go ahead and drag and drop those .ttf files from the desktop to the windows fonts folder.repeat this step until they're all installed. you can delete the desktop files afterwards. The fonts are installed now and won't be going anywhere .
Mar 13, 2012 | Computers & Internet
Hoe to download madura font (free)
1. Download the font below... Madura Font
(when u open it it will be just a english font, dont worry about that)
2. Go to your downloads where u save the madura.ttf file, COPY it (select, Ctrl +C)
3. IMPORTANT STEPS
--Go to My Computer,
--then C drive (double click, where your operating system is),
--Double click on Windows folder (NOT Program files),
--scan through the folders and open Fonts folder, it should preview all the fonts installed on your computer.
4. Now Paste (Ctrl+V) the madura.ttf file that u copied in STEP 2. (it should say installing font when u paste it)
5. Open Madura Dictionary and it shuold work fine now.
I have tried this in Windows 8 computer so it should defineatly work fine with windows 7 and XP.
Madura Font
http://www.maduraonline.com/download/madura.ttf
Madura Software (you probably already have this installed because u only wanted the font, for other people who wants to uninstall and start from the beginning)
http://download.cnet.com/Madura-English-Sinhala-Dictionary/3000-2279_4-10571464.html
Peumal Pushpakumara
Monash University
Aug 19, 2011 | maduraonline.com Madura English-Sinhala...
Malayalam font problem in indesign
Shut down all programsand then find your font folder which is usually in C:windows\fonts or you can search your C: for the fonts folder. Once you find the fonts folder delete the malayalam font if it's in there.
Open internet explorer and go to: http://www.deepika.com/font.htm
  1. Click on "Download font" below
  2. Save font in C:\ --> Windows --> Fonts (some browsers may save the file name as a .exe extension. Add .ttf to the end of the file name mlkr0ntt_TTF. The file name should be mlkr0ntt_TTF.ttf to work)
  3. Restart your computer
Now open your adobe program and see if you can use that font.
Hope this helps! If not contact me and I can find you another solution.
Feb 03, 2011 | Adobe InDesign CS3
How to upload the new INR symbol
Install the below fonts
step 1 : http://posterous.com/getfile/files.posterous.com/foradian/N1tP4q7jagR6ej3v82aOEfG45qQ1QpHspimeQOBh5WePATALQdA9v3DWpnjC/Rupee.ttf
Step 2 : http://posterous.com/getfile/files.posterous.com/foradian/3UAMU7WINSptf5AKZPu2v0PFx9AuWoAuUvDiKk2dvBK5nGectr2029CQ7EdP/Rupee_Foradian.ttf
Now you can find 2 fonts in word document ..say rupee and rupee fordain. use rupee fordain to use all the alphabets along with INR symbol. it is mapped with the" ` " symbol which lies left to the ( !/1) key on the top
Thanks
Rajanetworking@gmail.com
Sep 02, 2010 | Computers & Internet
How to install Fonts in windows 7
hello nirav702,
To install Fonts in Windows 7, simply follow this step:
1. Download Your fonts and then unzip
2. Right clik on it and then click on properties
3. Under the General tab You will see an Unblock Button (click on it only if u see the Unblock Button, if it's not then ignore this step)
4. You can either drag and drop the font to directory: "C:\Windows\Fonts" or u can just double click on the font and install it
hope this help
Apr 14, 2010 | Broderbund ClickArt 19,000 Fonts Full...
Increase font size on Nokia E65 Mobile Phone
NOKIA SAYS THAT THE FONTS ARE NOT CHANGAABLE THEY ARE WRONG!
There is quite a simple way to change system fonts in the Nokia E65 phone.
The following is how I did it in my E65.
First you have to select the memory as phone NOT the memory card.
Then connect the phone to PC through the standard USB cable. When the phone prompts you, select “Data Transfer” NOT PC Suite”. Once the phone is connected you can view it as a removable drive. First check if a directory named “Fonts” exists.
If it does not exist, just create it in the resources folder. If it already exists, just make a backup copy of it.
Now, go to your PC Fonts directory (usually c:\Windows\Fonts) and do the following:
You can use any TT font I used a font called Baveuse.TTF as the bold I used the Baveuse3D.TTF as my normal font. You have to have (3) three fonts and they have to be renamed to what is below or it won’t work.
Copy Any (True Type you want) font file to:\resources\Fonts\NSSB60.ttf
Copy Any Bold (True Type) font file to:\resources\Fonts\NOSNR60.ttf
Copy again the same normal Bold (TT) font file to:\resources\Fonts\NSTSB60.ttf
The (3) Three fonts have to be renamed as above or they wont work!!!
Then just disconnect the phone from USB turn it off. Then restart your phone and put the memory back to the card and you will have the new fonts in place. This is how I did my E65 and it worked ok for me. If the fonts are to big just start over delete the three fonts and use a different font to you find one you like I like the Baveuse.TTF font its personal choice.
Oct 18, 2007 | Cell Phones
Won't read fonts
Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it (usually by scanning it) to original factory configuration or scan a label that would enable all symbologies.
Aug 03, 2007 | Opticon LGE1105RHHS-000 Handheld
Microsoft Office 2007 Basic for PC Logo
1,439 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
