Question about Samsung Televison & Video
Yoke gone faulty. Yoke No. E157951 not getting in market. TV model SAMSUMP 29 Inches. Party CDYF2918H (030925J).
techman
  • 3130 Answers
SOURCE: Adjusting CRT yoke for convergence
You shold not have to move the yoke. if the set will not adjust, find the problem in the convergence. It is probably an IC starting to fail. Good Luck
Posted on Aug 15, 2007
  • 1694 Answers
SOURCE: ZENITH ANALOG TV, CRT DEFLEXION YOKE
No Longer Available thru part distributors....you might try
E-BAY......T.
Posted on Oct 25, 2007
SOURCE: Does the TOSHIBA TA8445K Vertical Deflection IC fails when the Deflection Yoke is Dirty?
hola tengo un tv onwua que no me habre el verticar ya revise los voltajes y estan bien pero en la pata 11 tengo solo 7 voltios en ves de 12 voltios cual puede ser el problema de mi parte muchas gracias.mi email es ruben_148_2@hotmail.com.
Posted on Aug 15, 2008
bestdarngood
  • 3037 Answers
SOURCE: Refrigerator Maytag MSD2454GRQ - Ice Dispenser Yoke
I think this manual should be relevant to your fridge. Page 61 I think will give what you are looking for much better than I may be able to describe, let me know if it is still being a problem as I suspect the pressure that keeps the yoke on is what you are having problems with.
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Posted on Nov 06, 2008
SOURCE: When the yoke is pushed/pulled (the y axis of the
although this did not solve my problem, it is worth a try to reset the calibration settings stored in the windows registry.
These are the steps for it:
To recalibrate, first unplug the controller.
Go to start/run and type 'regedit'
The registry editor will have a list of folders on the left hand side. Go
down into the following folders in order.
HKEY_LOCAL_MACHINE (HKEY_CURRENT_USER if on VISTA)
System
CurrentControlSet
Control
Media Properties
Private Properties
Direct Input
Inside the Direct Input folder, delete any folder that begins VID_06A3.
Once done, close the editor.
Plug the controller back in and move all the
axes (including throttle) through their full range of movement 4 times.
Now go to control panel/game controllers/properties to see if there are any changes to the test screen?
If it helps you, it didn't do it for me ;) but I reckon it's worth a try
Posted on Jun 12, 2009
Where can i buy lg 29 ultraslim tv deflection yoke?
Contact the authorized service center for LG, to buy a genuine one. Electro help
Jul 22, 2014 | LG Televison & Video
Is yoke coil repairable or available to replave in 29 inch LG flat tv?
Yoke coil is not reparable. Replacement can be done, but fitting and aligning this coil to picture tube is a very skilled one, that a normal user can't never do.
Aug 22, 2013 | LG 42LC2D 42 in. LCD HDTV
Is it advisable to repair LG TV 29 INCHES SLIMMAGIC having Yoke problem? where to get the parts?
Deflection yoke problem is a major repair. Replacing it is a skilled work.
Jul 31, 2013 | Televison & Video
Helo sir, i have a L.G T.V. Model No kf-20p32..is blowing the horizontal output..i change the flyback tranformer ,bt is still blowing the horizontal output
Check all the capacitors connected to horizontal output transistor. Especially one connected with its collector to ground. a high voltage [1.5Kv]. capacitor. Replace them. Check for any short inside the winding of the yoke. It is difficult to detect the winding short inside the yoke. Connect an other yoke in place, after pulling out the CRT base card out of the TV. This you can make sure about the condition of the deflection yoke.
Oct 02, 2012 | Televison & Video
My LG Super Slim 29"
You don't have a deflection yoke problem, you have a pin cushion problem. Check the pin cushion transistor.
Jul 22, 2011 | NetTV DTV-29XF3 29" TV
The picture on my TV has changed to a cone shaped, with the RGB variations separated. This happened suddenly, after an afternoon of watching TV and it working perfectly.
yoke coil has gone in ur tv .the yoke coil will be around picture tube which controls horizontal $ vertical width deflection. take the help of service person to change it with same type.
Mar 21, 2010 | Samsung TXM2790F 27" TV
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Jun 19, 2009 | Mitsubishi WD-52725 52". Rear Projection...
York Coil Problem - TXN2726 27 TV
The part you want is called a "yoke", and not a "York". This is the electromagnetic coil that fits on to the neck of the CRT, and makes the magnetic field from the scan amplfiers to scan the the beam.
I don't know if you realize that when changing the yoke, the purity and convergence alignment will have to be done on the set. This is a job task that requires skill and a lot of practice. Not many service techs are very good at this type of setup. There are specific calibration patterns used for this type of setup. When changing the yoke, it is very common that the ring magnet assembly (convergenc and purity magnets) that is behind the yoke must also be changed. Some yokes come with this assembly together, depending on the model of yoke.
Some manufactures do not sell the yoke separately from the CRT. When the CRT is replaced, it comes with the yoke and magnetic assembly.
An interesting question would be is, how did you determine that the yoke is actualy bad??? It is extremely rare that this type of part fails.
Parts for CRT type sets are getting very scarce. Because the market for spare parts for CRT sets is decreasing very quickly, the clone part manufactures are also not making the generic type dedicated parts.
A way to have parts for your TV set would be to search for a used set that can be used for spare parts. You will have to hope that the same parts you need are also not defective in the used set.
In my opinion, if the yoke is actualy bad, I would be shopping for a new set rather than go through all this trouble. The LCD TV sets are excellent. There is no way that your CRT set will ever be able to perform like the new LCD sets.
Jerry G.
Apr 16, 2008 | Samsung TXN2726 27" TV
Televison & Video Logo
89 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
