Question about Canon imageCLASS D860 All-In-One Laser Printer
Black line down paper
Every copy made has a black line donen the right side of the copy
  • Anonymous Mar 13, 2014
    Brother HL2240D black line down the right hand side of page
    Genius:
  • 2,035 Answers
Please clean the scanner bed with clean cloth and then scan
Posted on May 14, 2008
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Black lines on faxes
Open up the document feeder (where you put paper to send) and look for wite-out on the thin glass.
If it's not dirty, you probably have a bad scanner unit. Uneconomical to repair.
Sep 23, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Canon imageCLASS D860 All-In-One Laser Printer Logo
318 people viewed this question
old marine
old marine
