Question about Belkin (F5D5231-4) Router
Cd/dvd player will not read disk. need help with setup and installing
    Scholar:
  • 104 Answers
What has a router to do with a cd problem?Not enough clarification.
Posted on Sep 12, 2010
  • dennis_parso Sep 12, 2010
    It's to do with your cd player.
    Clean the read detector with a cleaning disc.
    If this doesn't cure it,the fault is inside the player.
Toshiba DVD player
Does this happen with all discs? What disc are you inserting that gives this error? DVD?
Feb 05, 2008 | Televison & Video
It's not reading cd, or DVD
Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
Jan 03, 2013 | Televison & Video
CDR not found. What do I need to do?
“To install, and Update Hardware, click to open “Computer” from the “Desktop”, check to see if there is a DVD-RW Drive (D :), for external different (E or F:).
I. Look in the “Device with Removable Storage area,” see if the device is present, if so? Do the following: to “setup” the ('player') for “Installation.”
II. Right click on (DVD) “Media Player” select (“Install”) follow all instructions thereafter.
III. If the area is (Blank?), “go to,” and 'click' on the "Start button" click all “Programs” scroll for a Media Disk Player”, open, and do the (“same as above”) for the installation. *Note: “Do the same for “Setup” (above) “Install.”
“Did this solution help? Helpful Ratings Feedback, appreciated, thanks paul7of9”
Feb 10, 2010 | Rimage 2000i CDR 2 (52X), CD Duplicator...
I have trouble loading CDs. There is a place to
Make sure you are placing the CDs in the drive with the label side up. If the computer can read DVDs, it can certainly read CDs as well. Once the cd is inserted, wait and the autoplay should start the installation program for the software.
Dec 01, 2009 | E-Machines eMachines T3830 PC Desktop
How to install
put a CD Disc installer of PIXMA IP190, automatically run setup itself, but before installing it, turn-off first your PIXMA printer then follow the instructions and procedure on the screen. Good luck!
Jul 21, 2009 | Office Equipment & Supplies
Cd/dvd cannot be read by the player
EITHER CLEAN or replace THE OPTICAL LENS , try first to clean it directly with a DRY Q-tip ,and test player again. if it doesnt read , then replace the optical lens, hope this helps , AJ
May 19, 2009 | Televison & Video
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Belkin (F5D5231-4) Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
