Question about ASUS M2N68-AM SE2 Motherboard
I have an ide hardisk and it has an XP operating system but when i used it my new asus board the hardisk is detected but it cannot load the windows and its just always keep on restarting. does my 512 ddr2 667 has makes the problem and should i use a ddr2 800 to solve the problem?
  • 252 Answers
If you are attempting to boot from a hard disk that was from another computer you will have problems because of architectural differences. You would need to place it into an identical pc build. You can install a new operating system then read the disk as an external or secondary drive, or do a new install from CD onto the same disk.
Posted on Jan 07, 2012
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
My Asus P5AD2 mother board bios wont detect my Hard Drives or CD drives. I installed vista onto it and it worked. Then without warning it refused to start. Now it will not detect anything but the...
double check cable from the mainboard to your hardisk like IDE or SATA together with the power cord
just make sure if its fully inserted. boot up the the pc press delete to check UP THE BOIS IF THE HARDISK is connected.
let see how it works.....
Feb 05, 2011 | ASUS P5AD2-E Premium Motherboard
By startup fails to see IDE 0 and IDE 2 , says no channel 0 and channel 1. Is it possible that the cmos battery is empty?
Once your powered on the CMOS battery is no longer an issue. If it isn't reading the IDE or SATA channels it could be because they are not set in the BIOS. Check your BIOS setting and double check your cable connections. You also need to make sure, for IDE devices, that one of the drives is set to Master and the other to Slave otherwise they confuse the board and cancel each other out.
Jan 03, 2011 | Asrock P4VM8 Motherboard
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
Operating system not found
When you power up the computer press F1 ore F2 or "del" key toenter in bios then check your hardisk is detected or not.
If not then if you have desktop open cpu cabinet then reconnect power cable and ide or sata cable to harddisk also check your harddisk is set to master.
Jul 29, 2009 | Microsoft Windows XP Professional
Board not detect the hard disc
Check on the jumper setting of the ide and power cable
check if the ide cable is connected properly on ur mother board/try reverse if u are not sure it doesnt ur hardware.
Start on power button the then click on on delete continuesly until the cmos setup will appear then check ur hardisk and ur boot secquence.
sometime not delete are using using in opening cmos sometime f2 or whatever assign.
Use fdisk/to check ur partition/after that reformat in these case u can easily conclude if ur hardisk is bad or not
Jun 10, 2009 | ASUS M2N-MX Motherboard
Primary IDE master not detected
Hi darchie_1213,
Power off the system & unplug the power cord. Open your PC case. To remove any static build up from your body, touch the metal bottom of the case before touching any internal parts.
It sound like the primary IDE data cable is loose or the power cable to the drive is loose. Try disconnecting both & than re-connect them. If that does not stop the issue, replace the data cable for the primary IDE drive. Click on the link provided. The site will explain IDE connections & the differences between a 40-pin IDE data cable & an 80-pin data cable. (Pictures included & lots of helpful information).
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
Try the above first. If the problem continues the issue could be the hard disk drive.
Mike
Apr 11, 2009 | ASUS P5V800-MX Motherboard
I am facing Problem installing Windows XP with Asus P5RD1-VM series mothboard with SATA Hard drive. My harddrive doesn't get detected while installing Windows XP. While going for coping files for...
I would go into the BIOS and make sure your SATA controller is using the AHCI or IDE setting and not RAID, if it is using RAID then it may need to load a special driver to install windows.
This is the most likely cause of your problem, can you also check and make sure the bios is seeing the HDD at all?
Jan 21, 2009 | Microsoft Windows XP Professional With...
Help cannot detect hard drive
probably cable problem only. rechk your cable the IDE and the power supply. maybe loose connected. the hardisk your a mentioning not detected is that additional disk or just only one?
Apr 03, 2008 | Microsoft Windows XP Professional
ASUS M2N68-AM SE2 Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
