Question about Refrigerators
My saivod js zbj icemaker has stopped making ice the lid lifts up when turned on but will not go into the ice making mode help
catriver
  • 878 Answers
SOURCE: My subZero Model 245 Icemaker stopped making ice
Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, Catriver...post back.
Posted on Aug 21, 2006
watugot
  • 290 Answers
SOURCE: icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
  • 76 Answers
SOURCE: samsung rf267aars icemaker stops making ice
unfortunately it sounds like you have a broken tooth on the drive or driven gear of the ice maker, in this case you should replace the ice maker. The good news is that you can get a new one for about 85 bucks at your local appliance parts store.
Posted on Jun 23, 2009
Karthik316
  • 187 Answers
SOURCE: GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Posted on Jul 25, 2009
I need a user manual for a Perfekt JS-ZBJ-A Ice Maker machine
if you had used your initiative to try google, you could easily have found this:
SOLVED: Ice Maker Model JS-ZBJ need instructions - Fixya
www.fixya.com/support/t3954601-ice_maker_model_js_zbj_need_instructions
Jan 23, 2010 - Ice Maker Model JS-ZBJ need instructions I have an Ice Maker Model JS-ZBJ am looking for a manual or something to - Refrigerators question. I need a user manual for a Perfekt JS-ZBJ-A Ice Maker
Mar 26, 2018
SOLVED: Instruction manual for Perfekt JS-ZBJ-A
Jan 16, 2013
Ice maker js-zbj-A not making ice
Jul 5, 2012
Questions, Troubleshooting Help & Support Page 6
Jul 28, 2006
More results from www.fixya.com
i
f you don't bother to try, you just wait for someone to answer your question.
Mar 26, 2018 | Ice Cream Makers
try manuals.help (http://www.manuals.help)
Jan 16, 2013 | Ice Cream Makers
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
My icemaker seems to be broken. When I lift the handle up to stop making ice it doesn't stay up. I have turned off the water, but how do I turn off the icemaker itself. It is model number596.72914200 . It...
Good day,
Remove the ice maker and make sure the wire that is the shut off arm is inserted into the slot correctly.
If it is, the you can either replace the front module or the ice maker complete.
It is, as a rule not very cost effective to replace only the module, but that is your choice.
May 14, 2010 | Kenmore Refrigerators
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Icemaker want stop making ice
Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
227 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
