Question about Panasonic Lumix DMC-FZ7 Digital Camera
When I turn the camera on, this message appears on the screen: please turn camera off and then on again. Doing this doesn't solve the problem. And when I turn it off, the objective doesn't go inside.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
When I turn the power on, the screen shows "turn
This type of problem can be caused by either a lens issue, or power problem. The following web blogs delineates things you can try to get the camera working again. They say about 50% of the time they can be fixed trying their suggestions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of those things helps, try these steps:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the camera still doesn't work, you can take it in to a local repair shop, but get an estimate first. Repair can be high, and justify just going ahead and buying a new one.
Good luck, and hope this helps.
May 27, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
Please Turn camera off and then on again
This message usually appears when force has been applied to the lens.
Sep 12, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Message PLEASE TURN CAMERA OFF THEN ON AGAIN
Sometimes this message appears when force has been applied to the lens. Here are some things to try. Go into the setup menu and find "reset" to reset the camera. If that doesn't work, remove the card and battery...press all the buttons...insert the card and then the battery. You may have a lens problem that can only be repaired at a service facility.
Aug 13, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
FZ-20 "Please turn camera off then on again
i heard that if you gently tap the camera on a table, sometimes it works...but im not sure...it keeps doing that for my camera too.
Jul 26, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
It takes time to turn on
I hold the digital camera with the lens upward when I switch it on, and then the problem doesn''t occur and I can take pictures.
I hope that this workaround will also work for you.
Nov 13, 2007 | Olympus Stylus Verve / ?-mini Digital...
Panasonic Lumix DMC-FZ7 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
