Software for advent keyboard kbw100
I have probs finding the software to alter the 18 shortcut buttons on my keyboard can you please help me?
  • 66 Answers
Please provide the manufacturer name of the keyboard. The web site for this manufacturer should have a support section that has a place to download the driver for this keyboard that will allow you to modify and specify the function of the extra buttons on your keyboard.
Posted on May 15, 2008
Keyboard backlight
Dear Jaine,
I did not find any replacement keys for your keyboard, but I located in ebay some replacement keyboards for around US$ 20 that may be an option. Please, have a look at:
http://www.ebay.com/bhp/advent-keyboard
Hope it helps!
Best regards,
Miguel L. Martins
Nov 03, 2013 | Advent Computers & Internet
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Shortcuts have locked up on my pc
Conflicting Extensions
Add-ons, also called plug-ins or extensions, are mini-applications that attach themselves to independent software and add extra capabilities to the program.
Extensions can change a browser's interface, alter the behavior of existing operations, add new functions or install in-browser support for programs like Shockwave Flash or Adobe Reader.
Because these extensions make changes to the overall operation of a browser, they can also affect the shortcut keys.
Most browsers offer an option to run the application with add-ons disabled; if the shortcut keys work when extensions are turned off, one of the add-ons is at fault.
Key Reassignments
Programs like MapKeyboard, SharpKeys and KeyTweak can reassign the functions of each key on the laptop keyboard.
If the computer is running a non standard keyboard layout, certain keys might not behave or respond normally.
For example, if the "Ctrl" key has been disabled or is set to work like "Shift," shortcut keys won't work as expected because the keyboard is no longer using its default mapping.
If the keyboard layout has been changed in the Dell laptop, the registry will contain a Scancode Map entry in
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout or the language bar will show a keyboard language different from the default ("English (United States)," or "EN," for Dell laptops purchased in the U.S.).
Virus Infection
Malicious software can affect the function of peripheral components like the keyboard and mouse.
If the keyboard is exhibiting strange behavior for example, if certain keys do not respond or if keys output unexpected letters a virus is most likely the cause.
Running an anti malware software from within Safe Mode accessed by pressing "F8" on the Dell logo screen should remove any viruses interfering with keyboard response.
Browser Software
Upgrading or downgrading a browser on the PC can affect the Internet shortcut keys associated with that program, especially if the version removes a function that was once associated with a particular keyboard combination.
Alternatively, if you've switched to another browser, you might find that certain shortcuts that worked in the previous browser don't work in the new one.
For example, while "Shift-F10" opens a context menu in Internet Explorer, the same keyboard combination does nothing in Mozilla Firefox.
Hope this helps.
Nov 20, 2012 | ASUS Computers & Internet
Where can I get Advent Modena M201 Laptop users manual? I want to know what all the keys on the keyboard are for also how the webcam works.
Check this page for some basic info, including keyboard shortcuts, that you may find useful: http://www.uktsupport.co.uk/advent/laptop/modena201.htm
Despite thorough searching, I couldn't find the user manual. It doesn't appear to exist on the net.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 08, 2011 | Computers & Internet
How to create a shortcut icon of built webcam on desktop on Advent computer
find your application in program files open it view the icon write click create shortcut.
Nov 14, 2009 | Advent Netbook
Keyboard drivers for audio shortcut buttons
Download on Driverguide.com
user Username: driver2
Paswword: all
Nov 12, 2009 | Computers & Internet
How do i turn on my integrated web cam on my 'advent roma' laptop? It works fine when chatting on web chat on messenger, but i cannot turn it on for general use?
I dont have an advent - but there may be a keyboard shortcut.
Fn & F11 ?? maybe - I have a Sony and the keyboard shortcuts are decribed in the onboard user manual
Start > Computer >> Local disk (C) >> Documentation >>En(glish)
Sep 16, 2009 | Computers & Internet
I have an advent notebook with a built in webcam but ive looked everywhere and there is no way of turning it on to my knowledge, please help and tell me how to.
Why not in windows explorer. Right click on My Computer > Explore. It should list your cam below Hard disk Drive , CDROM drive, as Scanner and Camera as USB Camera / Composite Device. Dbl click to start the Cam
Dec 26, 2008 | HP Pavilion dv1000 Notebook
ADVENT KBW100 Aluminium Multimedia Keyboard
You dont mention what operating system you are using. Perhaps your system is going into hybernation causing the keyboard to turn off. Try the following...go to Control Panel, then select Power Options and click on each tab to select your options.
Dec 31, 2007 | Computers & Internet
Computers & Internet Logo
638 people viewed this question
David Payne
David Payne
