Getting 4:3 aspect ratio
I have a Samsung SyncMaster 2032 NW. My PC is a Dell Optiplex 8300, using Pentium 4 chip and Windows XP, SP2.
All my monitor will show is 16:9, so everything is stretched and squashed. I have downloaded a driver from Samsung, but no change. All I want is to be able to look at the Desktop, images and applications in their native 4:3 aspect ratio, with the black bars on either side of the image.
Have you any suggestions?
Rich B
  • 2 more comments
  • Richb46 May 15, 2008
    Would this problem be solved with a newer/different video card? I downloaded the NVIDIA control page software, but it does not include the aspect ratio part, perhaps because it recognizes that my video card is of the older 5000 series.
    The monitor was just purchased 2 months ago. What would I claim on a warranty claim?
    Very informative.
    My graphics card is an NVIDIA GeForce FX 5200. I will check the Dell website, though I did download the current driver for the NVIDIA card two nights ago, and there was no change and no obvious way to make a change.
    Would you go ahead and suggest a video card upgrade, so I have that information in my back pocket?
    Thanks!
    So, is the problem that I am using analog output to my monitor? Would my PC have the capacity to provide digital output to the monitor. The monitor itself does allow for digital input.
  • 1,031 Answers
Right click on the screen go to properties then setting change the screen resolution to 1,024x768 pixels you will get an aspect ratio of 4:3-you'll see black bands at the top and bottom of the screen. This may be acceptable for many applications, when working with graphics, it may be difficult to evaluate the image. To restore order, switch the full-screen option off before doing any serious graphics work.
Posted on May 15, 2008
    Master:
  • 788 Answers
The scaller circuitry in LCD monitors are not designed to display anything in 4:3 like a 16:9 TV will do, they are designed to fill the entire width of the screen. If you select a widescreen resolution in your display properties then your pixels will be square and images will not look stretched. The optimal resolution for your screen is 1680X1050. If you find that too stretched then you can pick something like 1280X768 but the image quality will not be optimal.
There is a chance that the video card in your Dimension 8300 is not compatible with widescreen resolutions. Determine the type by looking under graphics adapters in device manager then update the driver from Dell's website if you don't get any widescreen resolution in display properties.
If any of this sounds like giberish to you then just get me the type of video card in your system and I can help you determine if you are capable of widescreen.
If by chance your computer cannot display widescreen then I can point you to which video card upgrade would work.
  • 2 more comments
  • Dean Joly
    Dean Joly May 15, 2008
    The only aspect ratio settings I have seen in the driver or video control panel will accomodate 16:10 resolution by adding the horizontal bars at the top and bottom, but any non-widescreen (4:3) resolution is always stretched to fit the screen.
    Since your monitor (not sure about the computer) uses an analog (15 pin VGA cable), and not DVI, the monitor is exactly that, a monitor, it does not manipulate the image at all. Monitors are not like TVs.
  • Dean Joly
    There is nothing wrong with your monitor or your computer, a 4:3 image is not usually possible on a 16:9 monitor.
  • Dean Joly
    According to the user manual found here: http://www.samsung.com/us/support/downlo... that monitor only has the vga (RGB IN) input and no DVI so you are stuck using the anolog connection.
    Did you check in your graphics properties control panel for 1680 X 1050? Since you have the latest available driver straight from nVidia there is nothing better that Dell can offer you.
    I'm going to try to find out if the FX 5200 supports widescreen.
  • Dean Joly
    After searching on google for FX5200 widescreen I see that no one seems to be able to get a proper widescreen resolution from that card.
    You computer uses AGP for it's video card connection. If you don't game get something like the Radeon X1300 or X1550 in Agp or Geforce 7300GT or 7600GS in AGP don't spend more than $70. If you want to play games ATI has recently released the 3850 in AGP for about $180. The key word here is AGP, don't get any card that is PCI-Express.
    Sergeant:
    Champion:
  • 230 Answers
Some connections inside will not be proper i think check for that.And i think that your monitor is an old one and it is going to reach its life end so if warranty is there claim for that
  • balachander megavarnam
    balachander megavarnam May 15, 2008
    first check whether the video card you have downloaded suits your computer and then proceed
    in desktop right click and in that go to properties ->settings and in settings change the screen resolution it may help
    Genius:
  • 3,422 Answers
Do one thing just try openieng up the graphic properties of your graphic card and then change the ration to 4:3.
Goodluck..
  • Priya darshan May 15, 2008
    And one more thing.if it is possible for you to go to the control panel then just uninstall that graphics drvier and shut down your PC and then if your having an external graphic card then just remove it from the slot and reattach it.If you have an internal one then just restart your PC once you uninstall..This will fix it..
    Please let me know if you need anymore help
    Guru:
  • 1,894 Answers
Off the monitor for few hours and use it
tell me what happens then
  • 1 more comment
  • dewan nafees ahmed May 15, 2008
    i dont think its vedio card.
    first of all goto setting(video) of ur OS and try to change to aspect ratios.
    it must be with in ur reach surely.
    if u r nt able to do it means apply to default settings.
    if u r nt able to clear with this then please post reply.
    i wil give some other fix.
    ya u can happily claim that for a warranty.
Syncmaster 152v repeatedly pops auto adjustment window
HI,
If you've changed the monitor recently, have you checked to make sure the Sync rate is not to high for the montior?
Steve
Nov 28, 2010 | Samsung SyncMaster 152 B 15" LCD Monitor
I have a dell Optiplex gx260. I bought a nice big Acer 23"monitor 1920x1030 but the max resolution in the graphics properties is 1280x1024 so I get a stretched screen or a poor resolution
jenny_beech
The resolution 1920x1030 is not a standard resolution. Also at the time this computer came out you did not have monitors this big ether. So you most likely will not be able to get 1920x1030 on this computer. However if you install the drivers for the monitor on the computer you should atleast get the right aspect ratio so you have poor resolution. You should have a CD with the drivers on in it. The llink below will show you haw to install them maually in Windows 7 if the drivers are not in an installer. Let me know if you need the steps for Windows XP.
How to install your monitor drivers in Windows 7
Issken
http://www.fixya.com/users/issken
Sep 30, 2010 | Dell OptiPlex GX260 PC Desktop
How to change aspect ratio?
change it by right clicking on the desktop and then selecting, in vista, personalize>display settings, or in xp, properties>screen resolution
Aug 06, 2010 | Samsung SyncMaster 2253BW LCD Monitor
Dell GX260 has distorted video on Dell 19" widescreen. Circles turn into ovals.
Most likely the Display Resolution is not set to a 16:9 display aspect ratio (1366 x 768 for example) if you use a 4:3 ratio on a widescreen, then everything is distorted. Make sure the display is set to the optimal resolution You can look up you monitor's Optimal Resolution here:
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~subcat=54&~cat=3
Jun 16, 2010 | Dell OptiPlex GX260 PC Desktop
No graphic after install XP SP2
Have you updated XP to SP3 as recommended? Did you  installed the latest available video driver after after that ?
May 26, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Monitor compatibility
It will be compatible with the system, just keep on thing in mind, whatever resolution you set your computer at you may have to keep the ratio aspect active so that way the screen looks properly displayed.
Jun 27, 2009 | Dell OptiPlex GX260 PC Desktop
Display resolution goes from 1024x600 to 800x600 at start up.
try reinstalling the drivers for the onboard graphics and for the monitor. Might be the monitor is not supporting the default resolution.
Jan 18, 2009 | ASUS Eee PC 900 Notebook
Computers & Internet Logo
601 people viewed this question
David Payne
David Payne
