Question about HP JetDirect 600N Print Server
I have HP P2015dn. I try to connet it to DLink DIR-601 router, but it doesn't work. I heard someone said I need to manually set IP address for the printer, but I don't know how to set it. Any know, please help.\r\nThanks a lot.
  • HP Master
  • 32,281 Answers
To configure the IP address on the HP's print server's network settings, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3582833-installing_a_network_printer
Posted on Sep 12, 2010
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Dir-601 doesn't work with windows 8
I don't think it's Windows 8. Connect a ethernet cable fron D-Link to computer. Is your Wireless Adapter Enabled on the computer. Unplug the D-Link, shut down the computer, unplug, remove battery, plug in D-Link , allow it to selftest, plug in computer, boot normally.
Dec 15, 2012 | D-Link DIR601 WirelessN 150 Home Router...
I have a dlink DIR-615 attached remotely to another home router system. It is hardwired via a LAN port and I connect to internet via the remote DLINK router via wire or wireless just fine. Problem is I...
After you change the IP address of your Router, you have to reset your Network Card IP address if it is Dynamic. If your IP address is Static you need to manually make these changes from within Windows. Else, reset your computer and try accessing the newly issued IP address for your Router.
Close all Browser Windows and Programs before continuing.
From the Command Prompt, type:
C:\> ipconfig /release
Press Enter, and then type:
C:\> ipconfig /renew
Now try and access the New Router IP.
Oct 24, 2011 | D-Link Computers & Internet
I lost my Dlink wireless router Setup CD where can i download the setup software ? Dlink wireless router N150 model: DIR - 601 thanks
Hello frederika_ra,
Go here: http://www.dlink.com/dir-601
Click "Support Resources" and everything you need should be there. I do not believe they allow a download of the software but you can use the manual to setup the router.
Hope this helps!
Jul 05, 2011 | Computers & Internet
My dlink dir-655 lose connections every few minutes, no idea why? Can someone help??
This could be because of the security settings not being compatible with the unit trying to obtain an IP address.
I would suggest taking the wireless security off completely to see if the problem perssist and try using the highest security possible.
Good Luck
Nov 20, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
I got d-link dir-615 wireless router and a 2wire modem 2071-a and when i set up the d-link router my desctop computer that is pluged into d-link cant get internet im 11 and got no idea wat to do oh and the...
does the computer that's directly connected to the modem connect to the internet? If not then make sure your settings are well set, your service provider (ISP) and all the other settings that your ISP supplied you have not been tempered with or modified.
Does you WDS and router communicate? Have you changed the IP addresses form the default ones that came with your devices? They usually begin with 192.. at times the default IP addresses don't work in some institutions. You can configure most DLinks using internet explorer by typing in the DLink IP address bar.
Considering your age, you need someone to show you how these things are done.
Aug 24, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
I just just changed my Linksys Router for a new DLink router model DIR 628, everything else on my network is working fine as before however I cannot print to the HP 5200 tn printer. The help line at DLink...
The Manual with the printer should tell you how to set the IP. Your best course of action however would be to set your router to broadcast DHCP and set the printer to obtain IP automatically from teh router. This will resolve any future issues you may have changing the router out.
Aug 23, 2009 | Computers & Internet
Need software for dlink dir 301 wireless router
Here is the link to the manual for your router. Follow it's instrunctions to login into the router and from there you can run the setup wizard. If you feel comfortable in doing so, you can set the wireless configuration manually. Please reply if you need specific assistance.
http://74.125.93.104/search?q=cache:FT1VlyIdfuUJ:ftp://ftp.dlink.co.uk/dir_products/dir-301/DIR-301_Manual_English.pdf+dlink+dir+301&cd=5&hl=en&ct=clnk&gl=us
Good luck and thanks for using FixYa!
Apr 09, 2009 | Computers & Internet
HP JetDirect 600N Print Server Logo
376 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
