Question about Fuji FinePix E550 Digital Camera
Can't take picture
I dropped my camera while taking a picture and now the zoom lens is stuck out. It won't close and it won't let me take a picture. Any Idea what I might have broken And how to fix it?
    Problem Solver:
  • 4 Answers
I'M NOT AN EXPERT BUT CURRENTLY ON MY THIRD FUJI CAMERA. THE "FINE PIX" CAMERAS TAKE FANTASTIC PHOTOS BUT ARE DELICATE IN SOME WAYS BUT FOR THE PRICE THEY ARE HARD TO BEAT. MY FIRST A500 HAD THE SAME PROBLEM FROM THE SAME EXACT CIRCUMSTANCES.... TALKED TO 2 DIFFERENT CAMERA REPAIR SPECIALISTS AND TO THE AUTHORIZED FUJI REPAIR CENTER...... ESTIMATES FOR INDEPENDENT REPAIR AND FROM AUTH. FUJI CENTER RAN ABOUT DOUBLE THE COST OF A NEW UNIT... BEST ADVISE IS TO START SEARCHING "BEST BUY" OR "CIRCUIT CITY" ON-LINE SPECIALS/ CLEARENCE
Posted on May 14, 2008
I dropped the camera and the zoom lens got off line. It won't close or go back in the camera. It looks stuck and I tried pushing it in but I'm afraid that I might push hard that it'll break...
The lens may be fixable but most likely will need to be replaced.
If the lens is stuck straight or won't come out at all it needs to be replaced.
If the lens is stuck at an angle then you may be able to snap it back to the center by pressing the edge of the lens back towards center while holding on the outer ring of the lens.
Hope this helps!
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
The lens won't close
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 27, 2010 | Canon PowerShot A540 Digital Camera
Zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
LCD monitor is black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 07, 2009 | Canon PowerShot SD890 IS Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
My camera is acting up
check the lens the lens might be closed if are open and hold for 5 seconds if it doesnt work take it to a specialist
Aug 07, 2009 | Olympus FE-170 Digital Camera
Lens is stuck open - will not close. still takes pictures
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 24, 2008 | Samsung NV10 Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Fuji FinePix E550 Digital Camera Logo
133 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
