Question about Ovens
Jen-air convection oven blower Model # WW2750
Need to replace blower motor. I have removed a plate at the back inside of oven. The shaft on the motor is sticking through some insulation. The hole opening is about 5-6 inches. How do I get to the motor from here
    Champion:
  • 254 Answers
From the inside you will find the fan. This will have 1 set screw or 2 set screws on the inside of the shaft housing.If you can remove the fan the motor will be on the backside of the oven mounted outside the cooking box.
Posted on Jun 02, 2008
I have no manual and i have no model number.. flat top with a convection oven. i need a manual.. please help
try Google with make and manual perhaps if you look the model is listed on a plate inside the oven door
Jun 17, 2015 | Ovens
Panasonic nn c784mf
Yes, leave the rollers and plate in there.
Mar 12, 2014 | Ovens
Hobart convection oven
You either have something hitting the convection blower wheel or the bearings in the convection motor are shot.
Feb 17, 2014 | Ovens
F8 heat low it goes up to 494 and stops there
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Aug 28, 2010 | TurboChef TORNADO Electric Oven
The digital control display is extremely dim
your model should be a jjw9527AAW.... usually when that clock assembly goes dim u must replace that clock ... for your model it is a part number #71003424.. that clock on sears.com is for sale at $186.06.. call around or shop around for a bettter price remeber shipping charges through sears though and prob take longer to get ahh nevermind ur call...ohh yea kill the power before servicing or call for service... hope this helps take care
Jan 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
Jennair 30" wall oven display is totally off.
Part # 71003424 runs around $185.00
It's a common issue in Jen-air ovens,the display burns out,the control itself will still work fine but you just can't read it.
Sep 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Thermador CMT227N
Hello air pro AC,
Welcome
You said, In the microwave mode - immediate clicking noise at start up. Oven, Convect modes work
Oh there are many things to check here.
1.look at the wheel base turning the plate that rotates your food for crumbs or sticking pieces of food.
2.check that the wheels are not worn down.
3.There can be a problem in the bearing, or linkage, or motor that spins the plate!
Do you get a error code?
How old is it ?
huuum
Waiting your response!
Oct 17, 2008 | Thermador Ovens
Jen air double oven
Convection ovens shouldn't be dripping anything. If you are making moisture-laden foods and the vent on the unit is clogged...even partly, you may have an issue. Inspect and clean. Pull the breaker!
Nov 20, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
195 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
