Question about Sharp AL-1540CS All-In-One Laser Printer
IS showing L 1 in the screen and stop working
  • 1,110 Answers
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Posted on Sep 12, 2010
Konica minolta bizhub 215 showing maintenance call(m2) and service call
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
Apr 03, 2014 | Minolta Office Equipment & Supplies
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
Buttons make numbers appear on screen
The keypad control board must be replaced in order to address the issue, but keep in mind the part alone is expensive.
Apr 18, 2012 | Microwave Ovens
SONY DSC T33 SCREEN STOPPING SHOWING. CLICK SONY DSC T33 SCREEN STOPPING SHOWING. CLICK BUTTON,FLASH WORKS AND IT APPEARS TO TAKE A PHOTO BUT NOTHING SHOWS. ALL ISONY DSC T33 SCREEN STOPPING SHOWING. CLICK...
I just replied your previous question that this problem occurs due to ccd imager chip failure that will be replaced to get live view in camera mode to take fresh pictures.
Local camera repair shop will replace it, let me know if you need part number of ccd imager chip of DSC-T33 camera.
Sep 28, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
This is due to failure of ccd imager chip in your camera, replace ccd imager chip to get live view in lcd to take fresh pictures.
Let me know if you need ccd imager chip part number.
The display screen is showing CL. Nothing is
CL is child lock. See your users manual for unlocking the child lock procedure. Usually it involves pressing 1 or 2 buttons for 3 to 5 seconds. Many machines actually have a lock button you press for 3 - 5 seonds. Others use the stop pause button.
Kelly
Aug 30, 2010 | LG WD-1280FHD Front Load Washer
How do I correct a blue screen stop.Shows on sreen xxxSTOP;0x0000008E(0xc000001d,0x80572dff,0xed5e4bc6,0x00000000) Tech info is ...
this blue screen problem generally appears if you install an incompatible driver .. can you please specify is you installed anything after your system was working normally
Sep 13, 2008 | HP Computers & Internet
HP Photosmart 3310 All-in-One Scanner stopped working
No scan options
Refer to device documentation to troubleshoot.
Aug 15, 2008 | Office Equipment & Supplies
Sharp AL-1540CS All-In-One Laser Printer Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
