Question about Olevia Televison & Video
Hi I want to connect my PC to TV in order o see pictures thru YOU TUBE application. I hv a loptop which is having HDMI. My HDTV model is OLEVIA 532 - B21 what kind of cable for connecting these will be required pl advise. ANAND
  • 92 Answers
SOURCE: 532-b12 code for fios remte
go to www.verizon.com look up fios tv and go to equipment and there you will find the codes for the remote
Posted on Dec 15, 2008
  • 6 Answers
SOURCE: olevia 32 LCD HDTV
The electronics are known to go bad with these 532-B12 TV's, and if you have NO picture, that's probably what's gone wrong.
These are LCD TV's, not plasma, so they don't leak (or, if the crystal layer leaked, you'd see more of a damaged picture, as opposed to NO picture).
I've actually got one of these TV's that I dropped, and cracked the LCD, and that's exactly what happened.   ...In fact, I'm looking for someone who has a TV with a good screen but bad electronics, to buy from them so I can swap the screen into mine, and so they get a couple bucks at least rather than tossing it to the curb... let me know.
I don't think that 1.5 years is long enough for a TV... the TV in my living room is almost 10 years old and working like new still.  Sadly, repair costs might be more than it's worth, especially with all the deals you can find out there right now.  But research it.
Let me know what you decide though, if that TV is truly broken, I will gladly give you a few bucks for it.
Posted on May 17, 2009
  • 10 Answers
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
budmrtn
  • 11361 Answers
SOURCE: My olevia 532 lcd hdtv
Check the power supply module for bad caps with leaking/bulging tops, check the backlight inverter board for short circuits.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 07, 2010
I need an owners manual for about a 2009 olevia 32 inch lcd tv and for the remote also.
Olevia 527V User Manual
This manual is for all the Olevia 5 series tvs(526,527 and 532). Around page 30 it shows instructions for the 532 remote.
Feb 22, 2017 | Olevia Televison & Video
Olevia 532 base stand screw
hi, did you find your answer? I have the same problem. eointosullivan@gamil.com
Jun 27, 2012 | Syntax Olevia 532H 32 in. LCD HDTV
Does ovelia model 532 B-12 come with built in tuner.
I purchased a 532-b12 several years ago - it includes both an analog and digital tuner.
Feb 13, 2011 | Syntax Olevia 532H 32 in. LCD HDTV
The calble is connected directly to the tv, not through the cable box & when i try to change the channel it says "no signal" at the bottom left corner. Olevia 32" model 532-b12
I assume from your question that you have a cable subscription and that you have the cable plugged into the ANT input via a co-ax cable. The ANT input is for an antenna for over-the air signals. The channel up/down change the internal tuner up/down. For example, if your cable is set to channel 3, it will pull in the cable on channel 3, but then try to pull in over-the-air if you hit channel-up to channel 4.
It seems you need some kind of converter box from your cable company in order to change the cable channels, and then that converter box would plug into either the ANT input (and leave the tuner on 3) or into one of the other inputs like Component, HDMI, SVideo etc.
Want to connect my thinkpad to the Olevia 532-B12 CD TV. Cables I have found show 15pin conenctors for the video and signle RCA plugs for audio. The back of the TV indicates it needs an audio splitter...
what connections to you have on your computer? because it is best to match connections with tv to computer. s video? hdmi? they sell av or color stream cables with a splitter to connect to computer color stream is just for picture av (RCA input) is for both video and sound.
Jan 31, 2011 | Olevia Televison & Video
I have a Olevia 532-H that I am unable to scan under the channel set up.
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Apr 22, 2010 | Syntax Olevia 532H 32 in. LCD HDTV
I have an olevia hdmi capable tv and a non hd verizon box what do i need to hook it up cable wise
The best picture would be HDMI, but as you stated the cable box is not HDMI. The next best connection is component cables (red,green,blue) from video output of cable box to video input of TV. You will also need RCA audio cables (red and white) from audio output of cable box to audio input of TV. I hope this helps.
Oct 27, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
Apr 12, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
Olevia 32 LCD HDTV
Oct 29, 2007 | Olevia Televison & Video
Televison & Video Logo
42 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
