Question about Janome Harmony 2041
The underside is sewing with loops and then gets jammed..?
  • 161 Answers
First try pulling all the threads out and rethreading. look for anything jamming the guides. try threading the top of the machine then cutting at the cotton real and pulling the thread out towards the needle, in the direction the thread should run. A good clean would not hurt.
Posted on Sep 12, 2010
SOURCE: JONES SEWING MACHINE PROBLEMS
We have a very old Jones Sewing Machine (1960's) we are having trouble with the thread at the moment. When we sew the thread gathers up underneath the material that we are trying to sew. Any suggestions to overcome this problem?
Posted on Apr 12, 2011
  • 323 Answers
SOURCE: pfaff sewing machine
You don't have the thread in the take up lever or it is not in the tension. Rethread it , Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.
set your tension to 5 and try it.
sewman7
Posted on Jun 18, 2008
SOURCE: Tensioning problem
When thread loops appear on the bottom, the problem is the tension in the top thread. If the bobbin tension was too loose, the loops would be on the top side of the stitching. This is true for all machines, whether mechanical or electronic.
Make sure you always follow these steps when threading the XL1000:
  • The presser foot must be UP
  • SNAP the thread into the first step of the thread path. Hold the thread taut with both hands as you pull it toward the front. You will feel the thread as it locks into the tensioner.
  • Be sure the needle is the right type and size for the fabric being sewn, that it is not dull or barbed, and that it is inserted correctly into the needle clamp with the flat side toward the back of the machine.
If you have threaded properly and still have problems, there may be bits of lint or other debris caught in the thread path or interfering with the thread sensor inside the machine. You can take the top cover off to see. Turn the machine off, and unplug the power cord.
There are 5 screws on top and two at the back right that have to be removed. Do NOT remove the small screw by the bobbin winder. Keep track of which screws go where as you remove them so they can be replaced properly. Lift the handle while the cover is pulled up, out, and away from the machine. It may have to be gently rocked a bit to work it free from the left side. Remember this when putting the cover back in place.
Use a good strong light so you can clearly see down inside. If there are any bits of thread or excessive lint, they should be removed. DO NOT poke anything metal inside. I use a bamboo skewer (from the kitchen). While the cover is off you can also add a tiny drop of oil to the areas directly over the needle area where metal moves against metal. Turn the balance wheel slowly to find these points. Use only name brand SEWING MACHINE oil and always use it sparingly. NEVER use household lubricants -- most are paraffin based and if used they will cause a gummy buildup that eventually binds the machine rather than lubricating it.
Replace the cover - remember to lift the handle to get it in place. Make sure the two little prongs at the top of the narrow front panel on the left front of the machine (where the thread goes down and back up) are placed in under the top cover before putting all the screws back in.
Plug the power cord back in, turn the machine on, re-thread, and run some test stitching. If you still have the same problem after going through these procedures, it may be time for shop service.
EK
Posted on Aug 27, 2008
RichSew
  • 184 Answers
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
Posted on Aug 07, 2010
  • 109 Answers
SOURCE: I think the bobbin tension is off - I have large
It sounds crazy but if you have loops on the underside of your fabric it means your upper thread is not properly threaded (and vice versa for loops on the top of your fabric). So re-thread your top thread, change to a new needle if you've been sewing with it for a months and you should be good to go. Let me know if you need any more help.
Posted on Aug 24, 2010
Testimonial: "thanks for the suggestion. My sister-in-law suggested trying a new bobbin and rethreading - which together worked."
Machine isn't sewing right. Underside thread is very loopy. Was sewing fine but thread jammed in bobbin area.
Remove all remnants of the thread from the bobbin area.
First thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the lot by thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. Also try new needle.
Oct 27, 2015 | Sewing Machines
My needle won't grab the bobbin thread but if I put some fabric in and start to sew the bobbin thread comes through. However, the bottom thread is all bunched up and causes the machine to jam.
the looping on the underside sounds like a needle thread tension problem. 1st off check top (needle) threading then turn machine by hand to pick up bobbin thread
Jan 02, 2014 | New Home HF-106
I teach sewing. A student had a problem with bunched threads on the underside of the fabric. I have tried figuring it out and every so often the thread stops looping. While sewing on the cg550 singer...
Make sure you have the correct bobbin, 66 class. Check the bobbin case. These machines use the apollo bobbin case that tend to get broken and then the thread hangs up.
Apr 27, 2011 | Singer CG550 Mechanical Sewing Machine
I think the bobbin tension is off - I have large thread loops on the underside of the fabric when I sew
Aug 23, 2010 | Singer Sewing Machines
The bottom thread on my Bernina 140 jams
Try pulling more thread out before you begin the seam - about 6". If you can hold the threads while you take the first few stitches that helps too.
Apr 02, 2010 | Bernina Activa 140
I have a Juki 654 Pearl - and the thread is looping on the underside. Tension adjustments don't seem to solve the problem.
Your hook might not be timed correctly. Sometimes a thread or fabric jam can dislodge the hook. When your needle is just starting to move upward from its lowest position, the eye of the needle should be just below the hook.
Mar 17, 2010 | Juki MO-654DE Mechanical Sewing Machine
When I sew, I get huge loops of thread on the underside of my fabric.
Large loose loops are a sure sign that it is not receiving any top tension. Re thread and be very deliberate going through the top tension mach. Check your book for the thread path if you have it.
Jul 28, 2009 | Brother Sewing Machines
Brother CSi 6000
have you adjusted the tension?
Jul 21, 2008 | Brother CS-8150 Computerized Sewing...
Janome Harmony 2041 Logo
74 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
