Question about Uniden BC248CLT Base Scanner
I need a instructions to program a Uniden bc248clt Bearcat scanner. I lost my manual and storm knocked all my frequencies out.
    Brigadier General:
  • 7,191 Answers
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Posted on Sep 12, 2010
How to program channels to Uniden Bearcat 248 ct scanner
Simple yet detailed programming instructions are contained in the factory manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 12, 2010 | Uniden BC248CLT Base Scanner
Lost owners manuel. need code install instructions. and also how to clear off all old codes
There is no general reset function that will clear all of the frequencies (they're not codes) from your scanner, but there are two ways to clear individual frequencies:
1. Programming "0.0" (zero point zero) into a channel will remove the programmed frequency.
2. Programming a new frequency into any channel will remove/override the previously programmed frequency.
You can download and print the manual for your scanner, at no cost, here:
Bill B.
Nov 16, 2010 | Uniden BC248CLT Base Scanner
I was given an old uniden bearcat 16 channel 10 band scanning radio bc144xl and i would like to hear all the fire,police and emergancies in my area but i have never had a scanner befor and dont know the...
Programming the BC248CLT is fairly simple, and detailed instructions can be found in the factory manual that you can download and print here:
What you can program and what you can hear will depend on your location. Many communities now use trunking systems and digital (APCO-25) systems, and your scanner is not compatible with either. For a comprehensive database of active frequencies and systems in your area, visit:
Bill B
Sep 12, 2010 | Uniden BC248CLT Base Scanner
How do I program my bearcat 144xl scanner?
The BC144XL is one of the few scanners that I haven't been able to locate a manual for, but programming it is fairly straight forward. Here's some guidance from Uniden:
Here are basic instructions for programming nearly all of the older scanners that Uniden produced. When the scanner is turned on press the MANUAL key, then press the channel number that you want to program first, then the MANUAL key again. This will stop the scanner from scanning and hold it on the channel that you want to program.
Then you enter the frequency (be sure to use the decimal point in the right area when entering in the frequency) and then press the E or ENTER button to save the frequency on the channel. You are now finished programming the channel. To advance to the next channel simply press the MANUAL key and enter your next frequency the same way that you entered it on the previous channel (as described at the beginning of this paragraph).
I hope this helps.
Jan 01, 2010 | Uniden BC248CLT Base Scanner
I don't have the manual for my Uniden Bearcat BC 855 scanner.
You can download/print the complete manual for your scanner by following the link below. It's a free download, and it provides detailed programming instructions. If you're programming a channel that is "empty" (showing 000.0000) just enter your frequency. Empty channels automatically show LOCKOUT but it clears with programming. The squelch setting will vary according to the strength of the signals you receive. Once you start scanning, turn the squelch down until scanning stops and you hear a hissing sound, then turn the control up slowly until scanning resumes.
For a comprehensive database of active frequencies in your area, visit:
Dec 30, 2009 | Uniden BC248CLT Base Scanner
How to program in frequencies into a BC144xl 16 channel iniden bearcat scanner
I can't find the manual for that model, but here's how to program it:
- Power the unit ON
- Press MANUAL to stop scanning
- Enter the channel number that you wish to program (01-16)
- Press MANUAL
- Enter the frequency to be programmed, including the decimal (example 156.25)
- Press E (Enter) to confirm
- Press MANUAL to advance to the next channel
For a comprehensive database of active frequencies in your area visit
www.RadioReferencve.com
Dec 27, 2009 | Uniden BC248CLT Base Scanner
Need programing instructions
try this website here it has all uniden products http://www.uniden.com/index/manuals_results.cfm?cat=3 i believe it uses the same manual as BC248CLT
May 16, 2009 | Uniden BC340CRS Base Scanner
Old bearcat 250 ---how to program it
download your model numers manual from uniden , pick your model from the list . it will guide you thru programming .
Dec 21, 2008 | Uniden BC248CLT Base Scanner
Uniden/bearcat BC-100
If it's indeed a BC-100 and not a BC-100xlt, the 16 channels are easy to program and use.
1. Press MANUAL 3 MANUAL with 3 being the number of the channel you wish to program.
2. Enter the frequency for that channel (e.g., 162.55) followed by ENTER.
3. Follow the same sequence for each channel you wish to program, except that pressing MANUAL after you program a channel will advance the scanner to the next channel.
To scan, simply press the SCAN button after your frequencies are programmed.
Bill B.
San Antonio
Jul 15, 2008 | Uniden BC248CLT Base Scanner
Uniden BC248CLT Base Scanner Logo
375 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
