Question about Cal Flame 5-Burner
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when match was removed.
  • 494 Answers
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
Posted on Sep 12, 2010
Where is the ignite button located
Hi phillzy21
If the main grilling burners don't ignite, try lighting them several times using the snap ignition. If that doesn't work, try using a match. In humid and windy conditions, sometimes the snap ignitions do not work properly. Make sure that the hood is fully open. Also, ensure that your gas is turned on and that the valve is fully open. Next, take out both the heat distribution plates and cooking grate. Turn the grill backwards, and hit the snap igniter a few times and look for a spark. If you see a spark, the igniter is working properly.
Bud
Oct 02, 2012 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
I would like to convert a grill that was used on natural gas back to propane. Can I just purchase a regulator and hose and be good, or do I need to change anything else on the grill?
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Can a Turbo STS 3 burner grill (720-0057-3b) be convert from natural gas to propane? Barbeque Galore has gone bankrupt and does not offer any assistance at their 1 800 number and I can't find any...
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
Aug 10, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Jul 04, 2010 | Ducane 30400042 (LP)
I have a BBQ Galore STS 4-burner grill. How can I
You need to look at the orifices to see if the hole on it is big for Natural Gas and small for LP!
Mar 14, 2010 | Barbeques Galore Turbo STS 4-Burner 169544...
The rotisserie heating element does not fire up on my barbeques galore grand turbo BBQ. Electric ignite seems to be working, but smell gas no heat
The rotisserie should have a thermocouple near the burner. If you have to hold in the knob, or push a red button to get the gas to flow to the burner, and the electrode sparks and the burner lights, you have to continue to hold the knob or button in until the thermocouple gets hot enough to keep the gas on. If the burner keeps going out, you could have a bad thermocouple.
Dec 22, 2009 | Barbeques Galore 38-inch Grand Turbo...
Not hot enough!
take it back to the store, natural gas is supplied at 1-2 psi, so its all up to your bbq, sounds like your burner is getting no gas(not much) it should not have a reulator at the hose, this is for propane tamks only
Jun 20, 2009 | Ducane 545 inch 2 - 3 Burner with...
Converting to gas
If it does not get hot enough when using natural gas then the small propane orfices must be sized larger for the equivalent BTU rating of propane. Conversion tables are online via Google
Jan 03, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Cal Flame 5-Burner Logo
264 people viewed this question
Top Cal Flame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
richie46
Are you a Cal Flame Grilling Expert? Answer questions, earn points and help others
