Question about Ovens
PF on surface back plate. None of the buttons activate except on th range burners.
  • 4,323 Answers
Hi
PF error means power failure. It appears when the power cord to the range is unplugged or due to a power surge. Try resetting the power to the range to check if the error disappears. Reset the power to the unit and check if the error still appears. If you have a Whirlpool range then you would need to replace the
ferrite bead kit (#8190596). In whirlpool it sometimes happens due to Line interference (electrical noise) from the direct spark
ignition module. Please check these instructions for installation to install the ferrite module--
Ferrite module installation instructions
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 12, 2010
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
HOW TO TAKE OFF THE TOP BLACK PLATE ON MY FRIGADAIRE RANGE PLGS389ECC
Good Morning Bob,
I see that you are having trouble with your burners and are looking for instructions on how to take off the black plate on your Frigidaire range, model# PLGS389ECC. First, I do suggest, that for these kind of repairs, you contact a local authorized technician. Second, I don't necessarily have instructions on how to take that plate off, but I have listed below, a link that will give you a parts breakdown of your range.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995457891.pdf
-Best Regards-
WP
Mar 31, 2014 | Frigidaire Ovens
Oven won't work says PF
Hello lornalang - Typically "PF" indicates power failure. Once again try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the range may possibly be experiencing a wiring failure or faulty EOC. Consult a professional to move forward accurately and to assist with the repairs.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Display shows PF-time of day flashing on Frigidaire range.None of the buttons respond. Rene
Try unplugging it to reset the main control board witch most of the time its your clock.then push enter.if don't don't work then your clock (main control is bad .or if it has a touch pad it could be bad.call repair clinic .com at 1-866-822-0890 or 1-800-269-2609 and order parts there.they can tell u how much
Nov 08, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool imperial series 465 electric range - light indicating a burner is on won't go off though all burners and oven are off
There is a fault on your plate sensor (the rod crossing through the center of the plate). You should be able to get a replacement if not you can replace the plate, but my advice is just ignore it. Its only there to make you aware that the surface is still hot during and after use.
Oct 23, 2010 | Ovens
Ignitor on Frigidaire model PLCS389DCC is not working. How can I replace it.
There are a couple of ways you can resolve this issue, depending on what isn't working. As it's difficult to determine by the brief description of the problem you're having, I can't tell if the main spark (ignitor) module is the faulty component, or if you need to replace a specific ignitor/orrifice assembly for one or more burners.
If none of the top surface burners are lighting when you turn them on, it is most likely the spark module that needs to be replaced. If it's only one burner that is not lighting, then you'll need to replace that burner's ignitor/orrifice assembly.
To get at these components, all you need to do is lift up the top range surface to expose the burner assemblies and the spark module. Be sure to turn off the gas line and unplug the range from the electric outlet to prevent any shock hazard, etc. Removal and replacement can be done with simple hand tools and by simply unplugging the electrical plug on the spark module.
Here's a exploded line drawing showing the components, part numbers, and a price list as well. You can order the part(s) needed online as well.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PLCS389DCC&productCategoryId=0122008&brandId=1428&modelName=DUAL-FUEL-RANGE&diagramPageId=00002&componentDescription=BURNER&documentId=R0504191&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
98 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
