Question about Amana SXD524VW Side by Side Refrigerator
Water leaking from bottom of side by side refrigerator
Water is leaking from the bottom of my Amana SXD22S2W side by side refrigerator and I don't know how to fix it
    Problem Solver:
  • 8 Answers
The is a fairly easy way if you have a strong stomach.
On the back of the refrigerator, you will see a plastic drain line running to a pan underneath the box. This is the drain line for the evaporator condensate water. It is stopped up in the refrigerator section of the box.
Here is the tough part...Pull the hose out of the back until you can wipe it off with a clean towel and blow hard through the hose with your mouth.
By the way ...take your food out of the fridge...you will blow some pretty disgusting stuff out of the drain and into your desert if you don't. This will cure your leak.
Pssst...you can used compressed air if you are a wuss! lol
Good luck
Posted on Jun 10, 2008
How do I replace complete water tube to ice water/ice maker, hole is inside refrigerator
Posted on Jul 12, 2008
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
How do I get access to the coils on an Amana model SXD22S2W,
on most refrigerators the plastic grill is a snap on most service tecks carry a long
brush that looks like a cats tail to clean the condenser coils a long bottle brush will also work but be gentle the tubing is metal the fan is normally located looking from the front back left corner if you have a plastic putty knife you can insert on top behind plastic close to the side and easily pop forward very few units are secured with screws ron
Dec 05, 2009 | Refrigerators
How do you get to the 1/8" supply line from bottom of freezer door to the water dispenser Amana SXD22S2W?
you will have to check the connections first.also you if the connections are there previously and you have to convert them to 1/8" then you can just connect the wire.but if there is no connection and you have to modify the unit then electrical connections has to be checked.but actually there is a electrical connections already in most of the units between bottom of the freezer and water line. you can click this link directly for the wiring diagrams/schematics http://www.applianceaid.com/image/samplecandiagram2.jpg --------- thanks.keep updated.
Sep 04, 2009 | Amana Refrigerators
Water is leaking from bottom on the side of
sounds like you may want to check your condensation pan which may be full and causing overflow each day.
Aug 14, 2009 | Amana ABB1927DE Bottom Freezer...
Door open all day Amana SXD22S2w
the evaporator is clogged with frost, just as if the defrost heater went out. Two options, remove all food and leave ref unplugged and doors open for half a day, or remove the back wall(evaporator cover) and defrost it with a hair dryer.
Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Nov 30, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Amana SRD522
sounds like water line is blocked with frozen ice. have a technician clean the line and check the icemaker and water line for any kinks.
Jul 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana refrigerator water dispenser
could be carbon particles from a broken carbon filter cartridge. replace the filter and flush about 5 gallons of water before checking the water again that comes out of the dispenser.
Feb 19, 2008 | Refrigerators
Amana SXD524VW Side by Side Refrigerator Logo
333 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
