Question about ASUS A7N266-VM Motherboard
After 4 seconds stops - ASUS A7N266-VM Motherboard
  • ASUS Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Sep 12, 2010
Bosch Rotak 32R. Why does it keep shutting down in 4-5 seconds??
Check gas cap for proper venting, will it run better with cap off.
Feb 13, 2016 | Garden
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
Samsung Dryer starts for 5 seconds then stops, but drying time still counts down.
I got the same problem and I tried to take off the belt let see the motor still running by itself but it still run for couple second then stop.
Jun 12, 2012 | Dryers
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
Combination rotation
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about Sentry Safes at www.SentrySafeShop.com
Dec 11, 2010 | Sentry Fireproof Safe
Is pattern to sentry 1230 safe right left righ
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
You can find more information on your Sentry Safe at www.SentrySafeShop.com
Dec 08, 2010 | Sentry Fireproof Safe
I love my bc796d and i have had it for about 4 years? My question is concerning the delay when scanning channels and i always keep it on 4 second delay. I would like to have it delay longer and thats where...
Setting DELAY for All Search Ranges
You can set the scanner to have a delay after the end of a transmission before searching
resumes. This slows searching, but helps you prevent missing replies on a frequency.
1:SERVICE OPTION → :CHAIN SEARCH → 3:DELAY
1:NONE
The delay is turned off.
2:1 SECOND
The delay time is 1 second.
3:2 SECONDS
The delay time is 2 seconds.
4:4 SECONDS
The delay time is 4 seconds.
28
5:INFINITE
When the scanner stops on a transmission, you must press RSM to resume
searching.
6: -2 SECONDS
The scanner only stops on transmissions for 2 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 2-second pause.
7: -5 SECONDS
The scanner only stops on transmissions for 5 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 5-second pause.
8: -10 SECONDS
The scanner only stops on transmissions for 10 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 10-second pause.
May 14, 2010 | Uniden BC796D Base Scanner
Cant set the second hand to move
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"]
To start/stop this, use the top button (Button "A").
To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A".
The "second" hand is the small dial at the 9 O'clock position.
In actuality, you 'could' start this and just not stop it...  Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
Nov 11, 2009 | Pulsar Chronograph Watch
ASUS A7N266-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
