Asus eee keyboard
Whenever i type a f i get fg, whenever i press spacebar i get a menu coming up, whenever i type v i get vh.
  • 2 more comments
  • mandferguson May 14, 2008
    I tried an external keyboard and it wouldn't work at all.
  • bgriffiths Jul 24, 2008
    any luck with this? having same exact problem
  • Addington Oct 09, 2008
    I just bought (Oct 2008) an ASUS eee 901 was working fine, then last night the key board developed a strange falt. if I type 1... I get 21, if I type 2... I get 21, if I type 3, I get 34... and so on, all the way across the numbers, also the Q key, I get Q plus Tab, and also various other keys have problems, tryed renstalling driver, external key board dosent work...
    Very Strange..
  • Anonymous Mar 28, 2009
    /Hey did u ever find solution? i have the same thing
    a sdw fgvhnjlklk
    Problem Solver:
  • 10 Answers
It's an internal problem. If ocurring after messing with the keyboard the solution is to turn off the asus, unplug the battery, plug it again and turn on. It happens in both 700 and 900 models.
Posted on Jan 28, 2009
  • 61 Answers
Check settings for keyboard in control panel 1st. try plugging a regular keyboard into laptop external keyboard port...some have keyboard input, some you have to use usb keyboard. If external works you might have problem with keyboard or connection inside laptop.
Posted on May 14, 2008
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
Asus keys problem
Move your hands in a swiping motion from left to right all around the keyboard, especially where the semi-colon key is. You want to make sure that no keys are sticking.
If it keeps happening then that means the keyboard is faulty and would need to be replaced.
Apr 27, 2010 | ASUS Netbook
1 on the keyboard is stuck, can you help? Whenever I try to use my eee laptop for anything that requires typing, it runs itself off with 111111111 Please advise!
This could be due to the keys area being dirty and sticky. Make sure your laptop is powered off and disconnected from power then gently remove the "1" key by using a house key or paper clip. Be sure to get underneath the "1" key and pull up until the key pops off. With the "1" key removed, clean the area under the key with a lint-free cloth. Replace key when finished.
Jan 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
My asus eee pc900hd runs on (skip spaces) while
Well the easiest way to narrow the root of the problem would be to eliminate whether or not this is a software related problem.
So basically you will want to do a fresh install of the operating system. If this fixes the issue GREAT! if not your keyboard is more than likely experiencing a short.
Think of your keyboard as a grid of horizontal and vertical wires, when you press a key, that key makes 1 horizontal and one vertical wire connect this tells the computer which key is being pressed that it is also making a connection for the spacebar.
If you need more clarification or help feel free to leave additional comments but I would start with backing up any files you have and formatting the harddrive and reinstalling the operating system
Nov 20, 2009 | ASUS Eee PC 900HD Netbook
Whenever im typing and hit the spacebar the cursor skips. its driving me nuts. pelase help me.
Could be something wrong with the spacebar on your keyboard. Try another keyboard and see what happens.
Hank
Aug 04, 2009 | HP Computers & Internet
My Asus Eee PC 701 SD has a stuck control key.
Shut it down (not hibernate), remove power supply and remove battery. Wait 30 seconds before reinserting battery. Boot the system.
In this doesn't solve the issue, your keyboard might be dirty. In that case you should clean it. Be careful if you choose to use a vacuum cleaner that you take measures to prevent your keys from getting into the vacuum cleaner.
May 05, 2009 | ASUS Eee PC 701SD 8G Notebook
Asus eee keyboard
Nope. It corrected its self after a few days and now its doing the same thing again. I've taken the keyboard out and cleaned it but still no luck. At the minute i'm using an ordinary keyboard on it. I might take it into a shop next week. Good luck with yours.
Jul 24, 2008 | Computers & Internet
Asus Keyboard Problem
Hi!
You may have a problem with the keys on your keyboard sticking. And it could be the ALT key that's sticking. You can try to remove the keyboard unplug and reconnect the cable underneath it. Or better yet, try an external keyboard see if its doing the same thing so that you will have a better conclusion if its the keyboard or just the settings on your OS or BIOS.
Hope this helps!
Karlox
Dec 26, 2007 | ASUS L 8400B Notebook
Open Questions:
Toshiba Virus Removal ' Remove Toshiba Virus - DataAlign ' Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
May 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
640 people viewed this question
David Payne
David Payne
