Question about Dryers
How to wire a modified start/reset switch on whirlpool AWZ220
  • 3 Answers
Not sure if thats a good idea...but i would just use a heavy duty toggle switch but this would mean you would have to manully turn it off when the buzzer sounded
Posted on Sep 12, 2010
I have a whirlpool azb 9750 and seems to have no pore but the fuse in the plug an the socket power is all ok, is there an internal fuse or thermal reset within the dryer
There are some overload/temperature switches within the dryer. Most reset when the overload/temp gone. You could open up the back and follow the wires to the overload switches and check with an electrical tester to see if you have power passing through each. The wiring diagram should be inside the dryer, and show each switch.
Jan 26, 2014 | Whirlpool Dryers
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
Is the thermostat attached to the heating element on a whirlpool awz220 electric dryer?
No, the thermostat is near it but should not actually touch the element.
Mar 01, 2011 | Dryers
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Washer goes right to drain when started
This error occurs if the touch-pad/LED assembly is not
able to transmit/receive data to/from the central control
unit (CCU).
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting
different cycles and changing the modifiers and
options available to confirm the touch-pad/LED is
responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit
(CCU).
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wont start, power to all parts, is there a reset button?
There is a wiring diagram on the access panel on the back, or in the control head.
Follow the path from incoming power through all switches and leading to the timer.
I suspect either the door switch or start switch has failed.
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool le5800xkno
Did you turn the machine off for 5 minutes and then restart it to see if it resets the system?
Oct 10, 2008 | Whirlpool GEW9200L Electric Dryer
My front loading dryer Whirlpool Duet GEW9250PLO will not come on even after resetting.
check for electrical power if you have 220+ then check the door switch, jump the wirers if necessary. If switch ok, then move timer to 20 minutes and press start--if timer ok then you must have a broken wire in the wiring harness. Good luck.
Sep 04, 2008 | Whirlpool GEQ9800L Electric Dryer
Open Questions:
Dryers Logo
110 people viewed this question
Top Dryers Experts
