Question about Car Audio & Video
Ok I have a 1800 watt SPL amp with 2 Pioneer 12'' 800 WATT subs in a vented box and last week I noticed only the the right one was working and I couldn't find any problem with the wiring so I bought a new one. When the new one was installed I was told it (the sub on the left) still didn't work because a wire inside the box was loose. They were able to fix the wiring problem so my old sub started working again. Now two days have passed of having both my subs working and now sub on the Right wont work nemore!! I dont know what to do this doesnt make any sense someone please HELP!!!
  • 625 Answers
Maybe the wires are disconnected inside the box. Remove the sub from the box and check the wiring.
Posted on Sep 12, 2010
What r the parametric specs for the ma audio hk15x2
Fo (Hz) : 29.581 QMS : 3.965 QES : .517 QTS : .457
VAS (liters) : 147.723 REVC (Parallel-Ohms) 1 SPL @ 1 watt/ 1 meter (dB) : 90.6 X-Max Linear peak-peak (mm) 70 LEVC @ 1kHz (mH) : 1.043 Enclosure Volume (Sealed) : minimum 2 cubic feet Fill Required % : 0 3dB down point (-3dB) : 43 maximum sealed: 2.5 cubic feet n fill required: 39 at 3 dB down point Enclosure Volume Ported Vented (cubic feet) : 5.0 Vented to Hz: 35 3dB down point (-3dB Hz) : 28 Square port area Sq/In : 80 Port Length : 13" Power Handling : 2000 Watt RMS & 4000 Watt Max. Make sure to use MDF for the enclosure and use 1 inch thickness and use braces as well. This is a beast of a sub woofer. So give it the proper power it needs and make sure that your box is very solid in construction. If installed correctly and given the right power, this sub woofer is bound to put a smile on your face and rattle your bones. I hit 142dB with only one of these subs and im sure if i gave it more power i could hit the 150dB range. DON'T FORGET TO GIVE IT THE POWER IT DESERVES. Have fun dreamsystems.
Feb 16, 2011 | MA Audio HK15X2 Car Subwoofer
Hey i just bought a new pioneer subs 2coils and a kenwood class d 1800 watt how can i connect them to get the clearest sound ?
That amp can run at 1 ohm so if your subs are dual 4ohm then run in parellel. All positives will be conected together and the negetives and then run to the amp.
-please give pos feedback david
Nov 09, 2010 | Pioneer Car Audio & Video
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
I HAVE TWO 15" MEMPHIS SUBS AND A POWER ACOUSTIK 1440 AMP. I AM PUTTING THEM IN MY 2002 SUBURBAN, WHAT IS THE BEST BOX TO USE? PORTED OR VENTED
that mainly depends on the type of music you will be listening to. If you need clean, punchy bass, use a sealed box. For more growl, and louder bass, use a tube ported or slot ported box. I would not recommend a bandpass box for 15"s but they do make them. I have 2 kenwood 12"s in seperate slot ported boxes with a SPL 1500 watt amp, making about 149Db in a 93 Eclipse. Let me know if this helps :)
Jun 15, 2009 | Lanzar OPTI1222D Car Subwoofer
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
550x2 subs....SPL z2x-820 Amp
The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
Hope this helps.
Mar 28, 2009 | SPL Dynamics Z2X-820 Car Audio Amplifier
Premier sub used to work great ... now nothing
Did you check to make sure that you didn't blow a channel in the amp? Another thing to check would be the connection on the inside of your box, maybe there is just a wire loose.
Dec 19, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
