Question about RCA HD52W59 HDTV Projection Television
Our TV is making a humming chirping noise and discoloration
  • RCA Master
  • 8,617 Answers
Replace the deflection board, thats usually the board that has issues when youre getting those symptoms.
Posted on Sep 12, 2010
2 Suggested Answers
  • 610 Answers
SOURCE: TV makes a loud humming/vibrating noise when
It sounds like the color wheel is beginning to fail and will have to be replaced. You can call Samsung at 1-800-samsung to find the closest service center. I would recommend using an experienced tech to do this repair.
Posted on Aug 22, 2011
I have 2002 dodge durango no noise or humming in park putit in reverse it has a humming noise hit gas noise stops put in drive noise starts again apply gas noise stops again anysuggestions please?
Check the transmission fluid level and condition. If the fluid level is off, correct it and then see what happens with the noise. If the fluid is discolored you should change the fluid and filter as a plugged filter can cause a noise.
Apr 08, 2017 | Dodge Cars & Trucks
RCA #RTS7010B, I'm using an optical line from my TV to my bar, it seems to work fine for Netflix and TV,however when I attend to watch a DVD or Blu-ray it makes a loud humming and chirping noise.
So from the tv there is an optical cble, what is from the dvd? Is there a cable direct from the dvd player or an option for one? What is the blyerau/dvd audio options or settings set to on the dvd ?
That may be where you need to look and confirm.
May 23, 2016 | RCA Televison & Video
I have a WD 65738. While viewing a program, the color becomes distorted, along with a humming sound. Status light stays green.
Hello, it sounds like your color wheel is going bad. the humming noise is usually the bearing in it going bad and it starts to distort the image and finally it will shut the set down because it is malfunctioning......tks
Jan 15, 2015 | Mitsubishi WD Televison & Video
TV makes a loud humming/vibrating noise when turned on. Screen eventually comes on but is discolored and noise continues
Aug 22, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
There has been a gray shadom on left side of screen, maybe 3 inches wide, for the entire length of the screen. I can see through the shadow, but it is noticeable.... any thoughts?
This tv have a colors wheel design in it.Flashes or discolors on this shadow?Tv making any humming sound or motor noises.Yes,mean the tv colors wheel is dying and spinning out of it motor axis.The color wheel,is the problems.Colors wheel sit way back of the tv,must take out alot of mechanical parts to get to it to replaced.U have no mechanical skills,don't tries this.Hire a tv tech to replace the colors wheel.
Jan 17, 2011 | Samsung DLP HL-P5663W 56" TV
Tv makes loud chirping noise but does not turn on
cost i about $100 from $50 just to look at it. not really worth it especially if it reaches $300. this is a transistor problem
Dec 26, 2008 | RCA F32650 32" TV
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Chirping noise
Sounds like something may be shorted out inside keeping the power supply loaded enough it wont start, dont recommend trying to fix unless you know EXACTLY what you are doing, there are some high voltages inside, I wold Call a TV tech out to repair, Just FYI, these sets from Phillips/MAG usually have CRT fluid getting cloudy causing discoloration/fog to pix around this age and older, between both repairs, some sets start around $1000, just an idea.
Jul 16, 2007 | Philips 60PP9352 60" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
