Question about White Sewing 1521
Dont have manual and need to thread the upper part of machine
  • 161 Answers
Http://www.sewingmanuals.com/
you should be able to find something close to your machine here
Posted on Sep 12, 2010
My singer 227 m was a gift i accidently took the bobbin out now dont know how to put back in also need the settings they need to be on please cuz the top thread is reallyy loose
If the upper thread tension is off, most likely it is threaded incorrectly or it is not seated in the tension disks. Remove the upper thread, RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point between high & low number to start and then tweak it from there.
A manual for your machine would be a tremendous help.
Instruction Manual Singer 227
SINGER Installing Front Load Bobbin Tutorial
Be sure to keep your machine clean and oiled--ONLY fresh, good quality sewing machine oil or liquid Tri-Flow Synthetic Lube from the hardware store. Open the top lid, the side over the needle bar and the bobbin area. Slowly rock the handwheel and apply ONLY 1-2 drops every place where metal rubs against metal. AVOID belts, plastic gears, cams. Be sure to move selector dials and levers and oil those metal mechanisms too. Doing this every 40 hours of sewing will keep your machine happy and healthy. Also, remember to change out the needles frequently--every 8 hours of use.
Jan 21, 2017 | Singer Sewing Machines
I DO NOT HAVE A MANUAL FOR 8708. I ALSO AM HAVING TROUBLE WITH THE UPPER THREAD,( PROPER THREADING NEEDED,) IT KEEPS BREAKING, PLEASE HELP. VINCENT
The manual may help (assuming this is your machine):
Crofton MD 8708 Instruction Manual
The thread will break if the machine is threaded incorrectly. Be sure to ALWAYS RAISE the presser foot when threading the upper thread. Also, set the upper tension to the midway point. This is the standard setting for machines although there may need to be some tweaking to get the tension where you want it.
Oct 20, 2016 | Sewing Machines
I have Bernia 180. The bottom thread is puckering. Top thread is perfect. I cannot find help in manual. Please help
Check that the bobbin is inserted turning the proper direction in the bobbin case and that the thread is threaded correctly through the tension control on the bobbin case.
Make sure the upper thread is threaded correctly. The factory standard upper tension setting is midway between high & lower number although this may need to be tweaked for your particular machine.
If the machine is still pulling the bobbin thread too tight, you can try tightening the upper thread tension. If it still isn't resolved, you may need to loosen the bobbin tension.
You might also want to check the presser foot pressure on your machine. That generally needs adjustment when changing from thicker to thinner fabric and vice versa.
Manual: BERNINA artista 180 Support BERNINA
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
How can properly adjust my tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 02, 2016 | Bernina Sewing Machines
I cant feed the overlocker.. so it dont want to work
Best to refer to the owner's manual. You can search the internet for the Make + Model + the word "Manual" and you may find a free download.
ALWAYS raise the presser foot while threading the machine.
Be sure to thread each in the order specified in the manual (usually, Upper Looper, Lower Looper, then the needles). Threading in the incorrect order will guarantee failure!
If a thread breaks or the machine messes up, it's usually best to remove All the threads and rethread from the beginning.
To start out, it helps to use a combination of different color threads.
Set the tensions to the midway point (the standard for basic overlocking).
Jul 20, 2016 | Sewing Machines
Brother pc 8500 upper thread breaks
Check the spindle the thread is mounted on and see if it\'s wrapped around it. Sometimes thread will catch and wrap around the spool spindle and break.
Check thread guides to be sure there are no nicks that might be catching the thread or damaging it.
Replace the needle.. a burr in the eye can cause upper thread to break. Needles should be replaced often, modern fibres can be hard on them, they get dull and that\'s no help for anything either.
Make sure the thread spool is mounted on the spindle with the thread coming off as directed in the manual. Some machines only work when the thread feeds in the right direction from the spool.
It can also be a tension issue.. tight upper tension or tight bobbin tension. Bobbin tension may be adjustable manually, but it\'s pretty rare for it be a problem. Upper tension, I don\'t know. I\'ve yet to get into computer machines so am not familiar with how they set upper tension.
But the mechanism that produces the tension can wear out or break and need replacement.
Jun 25, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Upper thread keep breaking
http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_PC_6000_EN_2572.PDF manual is at the above web site
Jan 26, 2014 | Brother PC-6000 Pacesetter
White Sewing 1521 Logo
16 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
