I have a Kleenmaid LTK96 Heavy Duty stackable washer and dryer. The washing machine is spinning slowly. I have checked the belt and tension - seems to be ok and the belt moves freely. Have looked up the manual and there doesnt seem to be any info on this problem. Any ideas thanks
  • wclark224 Sep 14, 2010
    Thanks for your help - cheers
    President:
  • 1,554 Answers
It is a safety feature of every front-loading machine not to advance to the spin cycle unless the door lock switch is activated and the door is locked. A front -loading machine spinning slowly is a symptom of a malfunctioning door lock and switch assembly. Check to make sure that the door lock and switch assembly connections are all good. But it is usually the door lock and switch assembly is the problem and repalcing it is the only viable solution.
Posted on Sep 12, 2010
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Dec 01, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
Duty heavy stackable
Hello Tabatha,
I see that you are having trouble with your washer portion agitating and spinning out. I suggest to give your appliance a hard reset. You will do this by either unplugging it switching the circuit breaker it is attached to, off for 3-5 minutes. Once the 3-5 minutes has passed, switch the circuit breaker back on. Turn the washer on. If you are still having trouble with it not agitating or spinning out, I suggest you contact your local authorized technician to come and diagnose the washer, to see why it will not agitate or spin.
-Best Regards-
Jan 24, 2014 | Frigidaire FEX831CS Top Load Stacked...
My stackable washer smells burnt and it does not cycle it tryies but then it spells like it is burning so i turned it off.
Hello serratosal - Based on the symptoms you are describing, you may have a broken belt or a faulty control board. Often when the belt is damaged, the unit will try to spin but it causes it to burn and eventually blow the control board. I would suggest contacting an experienced service technician to determine the root cause to reduce the risk of unnecessary parts.
Mar 21, 2013 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
The spin cycle is very slow. how do i tighten the belt?
there is no adjustment that can be made.either your motor windings are weak and causing the tub to spin slowly.or the transmission bearings are going out causeing extra tension and slowing it down.
you could have a bad belt as well over time they do get a little stretched and become loose on the pulleys.
Jan 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
We have a stackable kenmore washer and dryer. The belt started to slip and smoke on a heavy wash load. I replace the belt but it still smokes and wont spin. Is there and adjustment?
Hi, There are no adjustments. Make sure the pulley on the idler and the drive pulley are tirning freely. It is possible the transmission is locked up and the belt will not turn properly.
If all the pulleys are free, start the washer in the spin cycle while watching the drive pulley to see if it turns.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer makes loud vibrating noise when spinning. GE stackable washer dryer
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Jul 19, 2009 | Washing Machines
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
