Question about Rival 8401-M 4 Quart Ice Cream Maker
Motor making a squealing sound - Rival 8401-M 4 Quart Ice Cream Maker
    Problem Solver:
  • 16 Answers
First try cleaning the outer part of squealing blades with a soft cloth and try.
If not resolved then, you need to open the case and try replacing the blades.
If the problem is still not resolved, please replace the Iccream maker
Posted on Sep 12, 2010
When the left draw value is engaged the motor does not start on a consistent basis thus not having a smooth flow of soft serve
sounds like you may have a beater motor going bad and drawing high amps and not starting depending on where the motor stops the time before.
Feb 25, 2015 | Ice Cream Makers
My musso ice cream maker is making a knocking sound when on. Once ice cream starts to freeze it can't turn it any more. Loose belt? How do I fix or take apart? Thank you!
I would look at the motor itself. You will have to remove the cover and see what is happening. What I would be looking for is a loose motor mount or a missing/broken off mounting bolt.
Feb 20, 2015 | Musso Ice Cream Makers
How do you oil/grease the motor?
You don't, this is an electric motor. Oil and lubricants can cause damage to the motor or even cause a fire. If you feel that you need to have the motor serviced take it to a professional electrician who has experience in servicing such motors.
Sep 08, 2014 | Rival 8401-M 4 Quart Ice Cream Maker
Taylor 754-27 runs good until ice cream is made then trips-not able to restart in auto or wash-able to turn beater with hand-not binding - after ice cream becomes liquid able to start again in auto or...
It is possible that your viscosity is set too cold. You should check the temperature of your product to see if it is too cold. Is the Ice Cream hard? It sounds like maybe the beater overload is tripping. Some of the overloads can reset on their own. If you have and know how to use an ammeter, it would be beneficial to check the amp draw of the beater motor to determine if you are exceeding the overload or not. Ice cream is generally good at a temp between 16 and 20 degrees F. Temps vary with product and product brands. I hope this information helps, it is hard to determine exact problem without being there.
Oct 04, 2010 | Taylor 632-33 Ice Cream Maker
Machine is model 750-27can you help me? runs for only about 5seconds not long enough to make ice cream
Welcome to FixYa
An electric ice-cream maker is a tabletop appliance for mixing and freezing ice cream at home. A small electric motor drives gears that turn the canister filled with the ingredients for ice cream. The canister is surrounded with ice and rock salt to freeze the contents. Alternately, a hand crank on top replaces the motor.
Although durable, ice-cream makers can require a few repairs. A common problem is damage to motors or gears from mixing too large batches of ice cream or from neglecting a jammed mixing paddle. The electrical cord can fail and motor bearings can dry out.
Read Following ...
  • Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
  • Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
  • Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
  • Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
  • Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
I hope this Instruction guide will help you Click here Read carefully Instructions[Specifically Page27, 29,31]
OR click here
Just Check this Link too
Thanks for Contacting FixYa...
Jun 27, 2010 | Taylor 632-27 Ice Cream Maker
Taylor Icecream Machine Model# y754-27
Try slowing down the rate at which you are drawing the product from the machine,and giving it a minute or two between draws. If you take to much out to fast it starves the barrel and will cause it to freeze up,and that will make the belts squeal.
Dec 11, 2008 | Taylor 632-27 Ice Cream Maker
MOTOR DRIVE DOES NOT TURN
Dear Dannyvk,
I am having exactly the same problem with my rival 8200 ice cream maker. It worked once and stopped usual, when I first used it. The ice cream was wonderful.
However, when I started to make a second batch, the ice cream maker just hummed after I plugged it in. No movement of the pin/hub whatsoever. I tried to move it, by placing the steel can on top and moving it side by side. I plugged it in again, and experienced the same old humming sound.
Is it a fuse? Is the motor blown? Is this something that a small appliance dealer can repair at a reasonable cost? Can anyone help? I am so disappointed!
Faithful in Christ,
D.
Mar 12, 2008 | Rival 8210 2 Quart Ice Cream Maker
Motor Arm stopped working
All i can suggest is cleaning the contacts. Clean the metal prongs and the two holes they go into.
UNPLUG THE MACHINE
Use a q-tip cotton swab dipped in hydrogen peroxide or rubbing alcohol ... not both. After cleaning one hole wipe off any excess fluid before cleaning the other hole. These holes are a natural for catching stray drips of food or other kitchen goo.
Good luck.
Jan 13, 2008 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Rival 8401-M 4 Quart Ice Cream Maker Logo
108 people viewed this question
Top Rival Ice Cream Makers Experts
Henry  Thomas
Henry Thomas
Dan Webster
Dan Webster
Stan Skaggs
Stan Skaggs
Are you a Rival Ice Cream Maker Expert? Answer questions, earn points and help others
