Question about Magnum S9 Base CB Radio
Magnum s980 stopped giving me sound from speaker.also transmit scratchy.audio scratchy.
    Problem Solver:
  • 5 Answers
Pour gasoline inside of it and set it on fire for 5 minutes. When done crank up every thing that can be adjusted inside for more modulation and power. Cheap radio. CB junk.
Posted on Sep 13, 2010
Scratchy rec audio
Could be several things, controls need cleaning, use contact cleaner, could be bad speaker, replace, caps on audio section need replacement, service with correct components, could be bad audio amp, replace with correct replacement. Not enough info to say for sure
Mar 13, 2014 | Alinco Radio Communications
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
Magnum s980 SWR Light Flahing on keyup
Get your hands on a Dummy load and see if same issue--if not when RF hits the line a short exists (connector, coax, or antenna)
If same issue with a dummy load it may be in the radio if it has the SWR light the circuit may be reading wrong.
Apr 09, 2012 | Radio Communications
My magnum S9 wanders off freqency an the incoming starts sounding very scratchy, is there a mod ?
magnum s9 they seem to drift a bit on till they warm up my s9 dose the same on till it heats up then it comes ok
Jul 30, 2010 | Magnum S9 Base CB Radio
No sound on my Dell Dimension 3000
i would try checking the plug for your speakers to see if it is loose.
If you move the plug is there any static that comes from the speakers?
If you have headphones maybe try plugging them in to see if you have sound through them.
If you do have sound then i would say it is your speakers that are bad.
If you get no sound or scratchy sound through the headphones, then i would suspect either a loose jack connection for your audio or a dying audio chip.
Feb 14, 2010 | Dell Dimension 3000 PC Desktop
Magnum delta force
pin1 = mic audio,pin 2=receive, pin3= push to talk or transmit, pin5= shield.
cobra usually is white= mic audio, red= ptt, black= receive or speaker complete
Dec 21, 2008 | Radio Communications
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
Re: scratchy speaker sound quality
Have you tried with headphones?  Scratchy WITH heaphones. Reinstall driver. If it's NOT scratchy with headphones.  Either your speakers are blown, (which usually doesn't happen), you need to reinstall your sound card drivers, or bad settings.  Double click sound horn. Turn some volumes haflway, or mute sound channels you aren't using. Options Properties will let you show ALL sound properties. Ctrl+S makes the sound properties half size.
ReInstall Drivers: Start - Settings - Control Panel - System - Device Manager, Expand Sound Controllers, Right Click on your sound card, Click Uninstall.  Reboot and reintall.
Might ask to reinstall automatically.  Thats fine.  Install then reboot.  I prefer to cancel the install until I have rebooted.  But both ways tend to work.
Hope you don't have to change your speakers.  Need to pull your mobo to get to em. Instructions here pg. 5-55
James Mac
Sep 08, 2008 | Compaq Computers & Internet
One speaker not working and Scratchy Audio
just check is there any loose contact frm that speaker connection plug out the cable connect it again and have a check it may work...
or may be any time the speaker may be falled on ground so may be there is problem
Nov 23, 2007 | Gateway GMAX 5100 Computer Speakers
Magnum S9 Base CB Radio Logo
112 people viewed this question
Top Magnum Radio Communications Experts
John Porter
Jim Goldsmith
Jim Goldsmith
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
