Question about GPS
Could i i please have the manual to the Tekonsha Voyager 12 Volt Electric Brake Controller
  • GPS Master
  • 696 Answers
No problem!
Here's the link to your owner's manual:
http://www.marksrv.com/brake_control/voyager_manual.pdf
Hope this helps.
Posted on Sep 12, 2010
Gm stock trailer brake controller wiring ,when hooked up to the controller , turns the parking assist off (disabled),why or whats the fix ( all power wires hooked up, trailer brakes work fine )
the sensors are designed that way normal function when tow is set up behind vehicle if not the park assist alarm would be ringing/beeping all the time because of distance the trailer or what ever is hooked up to tow is to rear of vehicle your owners manual also explains this function
Sep 05, 2016 | 9030 Voyager Electric Trailer Brake...
When i pull my trailer ahead the trailer brakes lock up
The brakes system is surge? Not electric?
Probable cause is corrosion from sitting.. Rock the trailer back and forth while hitched( Not crazy like please- be gentle. ) Hit the brakes each way which takes a knack. It should break free. Problem is long term storage( over winter). They may also be stuck in reverse.. The controller. may need a hammer whack( universal adjuster)
May 05, 2016 | 9030 Voyager Electric Trailer Brake...
How do I wire a brake control unit into mitsubishi magna V6 auto?
the unit you buy will have the instructions for getting a 12 volt feed from the fuse box (never direct of the battery has to have a fuse )
the unit slide controller will be near the driver side and a 12 volt wire will run through that controller inside the car to the back of the car to the trailer plug connection matching up with the wires to the trailer/caravan horse float .electric brakes
Aug 29, 2014 | Mitsubishi Magna Cars & Trucks
Brake Box Will Not Work
First try a 12 volt "stab in" test light pushed into the blue wire at the brake controller. Red is brake feed from the truck, black is 12 volt power and white is ground. If all is wired correctly, the blue wire should power up when you hit the brakes. Be sure to turn the controller up to highest setting to test it. When you hook the test light up, the connection indication light should come on. Then turn red when you hit the brakes. Also see http://www.etrailer.com/faq-wiring.aspx for more info.
Oct 22, 2009 | Pioneer Voyager 4000 HD-DVR
Electric trailer brake hookup
Truck Brake control
Red/Black stripe Black
Blue Blue
Lt. Blue/white stripe Red
White White
Orange Not used
Jun 28, 2009 | 2006 Toyota Tacoma
Our truck has an Accupower Digitrac II electric brake controller
When I googled again, I found a reference which included a manufacturer's name - Tekonsha.
I then googled Tekonsha and found Tekonsha.com, and it led me to a technical support section in downloadable Adobe format with instructions for all of their brands of electric brake controllers. The instructions are very thorough and include installation, operation and troubleshooting.
Mar 30, 2009 | Dodge Ram Pickup 1500 Cars & Trucks
TEKONSHA BRAKES
if your brake lights are coming on when they want it could be the brake pedal switch it could also be a short in the controller
Oct 18, 2008 | 1995 Nissan Pathfinder
Trailer brake control
I use a AccuPower Pod brake controller, by Tekonsha. It is small, and easily adjusted. Most RV retailers can install them.
Jul 04, 2008 | Computers & Internet
GPS Logo
389 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
