Question about MTX 12" 2-Way Professional Loudspeaker (Each) - Black/Silver
I have a set of MTX speakers and they are HUGE. 40" tall; 16" wide; Gray/charcoal felt covering; each spkr has 2 - 12", 1- 4" and a tweeter horn on top. Can anyone tell me anything about these? Were they used for stage concerts ? How much power needed to drive them?
2 Suggested Answers
  • 13 Answers
SOURCE: i HAVE THE MTX TP112 SPEAKER, THE HORN TWEETER
It is a one piece horn need to replace the whole thing. These are not like normal PA speakers where the driver can be unscrewed from the horn lens and replaced.
Posted on Jan 14, 2010
I need replacement crossover because they got burn
The crossover in these is very simple and if it is burned, likely your speakers, maybe both, the woofer and tweeter have been damaged and need to be replaced. Test the speakers before changing the crossover. You MAY NOT notice the damage until you start driving the speakers again. The voice coil of the woofer is a common thing to fry, and while it may not open up, often it becomes unbonded to the coil form and rubs the magnet pole pieces. The tweeter/horn often wipes out the diaphram or blows the element open. Some of these are piezo horns and they can sometimes survive. These are rated at 100 Watts and if your amp can deliver over 50 watts you have to be careful to not put too much power into these. I have several of the Kustom 10 inch ones and several of the 15 inch ones... Also I have two 15 double stacks and they all seem to use the same crossover. Believe me, the crossover is far from what I would call "special" like the advertisements say. As an electrical engineer I was very disappointed. Anyway, test your speakers as they may be the worst of the problem.
Mar 27, 2011 | Kustom KPC12M / Phonic MAX 1000 Spkr & Amp...
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
How do i wire the crossover on the dxd210/213
If the crossover is made to accept speaker level input from amp then.....Amp/head spkr output + to crossover + input. Amp/head spkr output - to crossover - input. Crossover midbass + out to midbass spkr + input. Crossover midbass - out to midbass spkr - input. Crossover vari-tweeter + out to tweeter spkr + input. Crossover vari-tweeter -3 or -0 or -6 out to tweeter spkr - input. You have to choose for your preference. 0db makes the tweeter respond normally. -3db mean 3db lower in volume...and -6 means 6db lower in volume. Choose based on your liking.
Apr 12, 2010 | MB Quart - 5.25" 2-Way Component Speakers...
I HAVE THE MTX TP112 SPEAKER, THE HORN TWEETER STOPPED WORKING. CAN I GET A NEW HORN OR THE TWEETER ATTACHED TO THE HORN ALONE? I CAN'T FIND
Jan 09, 2010 | MTX 12" 2-Way Professional Loudspeaker...
Wharfedale
Hello georgesverme,
I'd recommend starting with the local importer of Wharfdale products to see if they have exact replacement tweeters for sale. Contact:
Bob Springston, Sound Import, LLC
Phone: (508) 422-9788
Email: sales@soundimport.com
If you are unable to get tweeters from them, see if they will recommend a replacement or at the very least, provide you with the specifications, including the impedance, crossover point,frequency response, and power handling capability. If they won't or can't provide the information, then you are on you own. You'll want a relatively high-quality product, most likely 8ohm (but could be 16), crossover between 5-8KHz, frequency response from crossover to infinity (or at least beyond the range of human hearing).
Then try www.partsexpress.com. They have a large selections of speaker building products and carry small tweeters like yours in several brands, price ranges, and quality levels. Vifa is excellent. Tang Band is good. Goldwood is acceptable for entry-level speakers.
Hope this helps.
Aug 06, 2009 | MTX Audio TX4001 Component Speaker System...
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Remove screen on MTX HT625AC ceiling speaker
as far as i know the tweeter is angled in the mount it does not look like the speaker can be angled as it appears to be fairly standard ceiling unit.
but the cover looks like a push on so maybe very careful levering might work.
Apr 20, 2008 | MTX HT625AC Speaker
My tweeters do not give sound
just run the tweeters to the front speaker channels on the radio
Mar 10, 2008 | MTX Thunder 1501D Car Audio Amplifier
MTX 12" 2-Way Professional Loudspeaker (Each) - Black/Silver Logo
24 people viewed this question
Top MTX Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MTX Audio Player and Recorder Expert? Answer questions, earn points and help others
