Question about Pioneer GM-6300F Car Audio Amplifier
For the speaker output section, if i wanted to wire up my sub and 2 speakers, which ports would i put the wires for the sub and the wires for the speakers?? i have a rough idea i just dont wanna mess anything up, Ch A R -R L- L bridged bridged R -R L- L Ch B if you could, possibly substitute an '-S' and 'S ' or whatever for which one the subs go in and '-SP' and 'SP ' for which ones the speakers go in? or whatevers easiest idk anything about these things
Shuttle83
  • 1139 Answers
SOURCE: speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Posted on Oct 09, 2007
Cerfer39
  • 709 Answers
SOURCE: wiring speakers to bridgable amp
I just answered this one
Posted on Oct 23, 2007
mjap
  • 107 Answers
SOURCE: wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Posted on Jan 26, 2008
zzedly
  • 300 Answers
SOURCE: prsx720
The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
Posted on Mar 16, 2008
It is simple. The MRV1000 can be bridged but only to a 4 ohm load. I am assuming your subs are 4 ohms and run fine stereo, but if you bridge them it will show a 2 ohm load bridged to the amp which means 1 ohm per side. The amp is not stable at the impedance. Get 2 ohm/8 ohm subs or "Dual 4 ohm voice coil" Subs and it will crank fine.
Posted on Apr 10, 2008
My sub woofer has only speaker wire connections. how can i connect to port on the dh500
I don't think you can. The port will be for a powered subwoofer. However you simply connect the one or both main speaker channels via your sub speaker terminals and the main left or right (or both) speakers to the other terminals on your subwoofer. It all depends on how many speaker terminals there is on the sub. If there are two- one input & one output- connect just the right main speaker etc.
Remember the the speaker out of the amp go to the imput of the sub. And the sub outputs go the loudspeaker.
Jul 14, 2010 | Sony STR-DH500 A/V Receiver
4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Dec 09, 2007 | Audio Players & Recorders
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Nov 12, 2009 | Kicker KX2500.1 Car Audio Amplifier
Need help wireing sub
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Oct 08, 2009 | Car Audio & Video
Wiring Speaker to amp
remove all speaker connections to your amp. MAke sure the inputs are driving all 4 channels, and that the built in crossovers on the amp are all set to full range. Conect your full range speaker to each output channel one at a time and verify there is oputput on all 4 channels. If all is ok, then connect your rear speakers to the front(a) outputs of your 4 channel amp, and then use the second 2 channels (rear or B) bridged to drive the sub. Re-configure the crossovers for highpass for front (to drive your rear speakers) and lowpass for sub. This is the proper way to connect a 4 channel amp with a sup whle driving 2 full range speakers.
Jun 10, 2009 | Car Audio & Video
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Converting 2 channel amplifier to 2.1 amplifier
it is not availlable to do such convertion.
Jul 05, 2008 | Audio Players & Recorders
JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
Mar 01, 2008 | Car Audio & Video
Operate amp @ 2 ohm
what is the output impedance of the unit - factory specs? use calculations for resistances in series or parallel to get what you want. for example if the amps output is 8 ohms and you have two 4 ohm speakers wire the speakers in series. if your output is 4 ohms and you have two 8 ohm speakers, wire them in parallel to get 4 ohms. another way is if you have one 8 ohm speaker and you want it across the 4 ohm output, find a wirewound resistor that'll take the wattage rated at 8 ohms and put it in parallel so the output sees a 4 ohm load.
Aug 23, 2007 | DHD NTX-2009 Car Audio Amplifier
Pioneer GM-6300F Car Audio Amplifier Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
