Question about Zenith MBR3447 Remote Control
I want to know how to use some features on my Zenith MBR3447 remote
I got this tv as a handmedown from my dad and I don't know how to use the following buttons: surf, pip, swap, freeze. any and all info would be much appreciated (I'm technologically impaired)
  • Zenith Master
  • 520 Answers
My guess is SURF might let you scan through the channels like a scan button on a car radio. PIP stands for picture in picture and may require a second device(vcr etc.) with a seperate tuner to use. SWAP allows you to swap pictures when useing PIP. Freeze probably will allow you to freeze the current picture on the screen.
Posted on May 15, 2008
Split screen
either you have the PIP engaged (two different pictures) or if same picture twice a digital issue in the set.
Look for PIP and turn it off or if a swap button see if it swaps the pictures--will tell you if PIP is issue or not.
Jun 07, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
WS-65611 PIP worked until cable tech connected new Digital Box
do u want pip form the cable box itself or watch dvd on one side then tv on other
Jan 25, 2008 | Mitsubishi WS-65611 65" Rear Projection...
I have a 1998 sony trinitron 27 inch television model no kv27S65. The picture in picture came on and I can't get it to turn off. Help! The info in the email is the correct model number not the info in...
You should have buttons on the remote for the TV which are SWAP and FREEZE and PIP. Pressing PIP should turn picture in picture ON and OFF each time you press.
Aug 13, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
Nov 30, 2009 | Vizio VW32L 32 in. LCD HDTV
How do you use the pip/swap buttons....
Go to rca.com , click tv then click support, drop menu size then drop menu model #and you can download user guide
Jan 11, 2009 | RCA D52W19 52" Rear Projection Television
Don't have manual...don't know how to use some buttons
My guess on surf is it might scan channels for you. PIP is short for picture in picture and may require a second device with a seperate tuner. SWAP works with PIP button and switches (or swaps) between the pictures. FREEZE probably "freezes" picture until you push button again.
May 14, 2008 | Zenith MBR3447 Remote Control
Help
Greetings Giselleriver,
Since you have the CT9951, I can only assume you have a CF27H50, CF32H50, or CF36H50 TV. You just need to make sure you have your video sources (i.e. VCR/DVD/Cable Box) connected to Video 1 or Video 2.
Once you have your video sources connected if you press the PIP button you should have a small screen that appears in the upper right hand corner, if you press it again it should grow slightly. To change whats in the window you should be able to press the SOURCE button, and if you want to exchange what your watching on the main screen the SWAP button should exchange the images.
If your not use one of the listed TV's and your unit doesn't come with the PIP feature, you can't install a PIP feature.
Happy Channel Surfing.
Jon
Go Ahead. Use Us.
May 07, 2008 | Televison & Video
Picture in picture
i am not familiar with this model, but on most sets you will have a button on the remote to activate pip, when active you should be able to adjust channels on the small display with the remote and cycle through inputs. depending on the tv you will either have 2 inputs for your cable/sat/tv feed, or will have 1 with a dual tuner.
check the connections in the back for a second cable input, or hook up a dvd/vcr/game console/etc to test the pip.
start dvd or tape playing, press pip button to display the mini-screen, then use the tv/vcr or input button to cycle through the modes and see if one pops up. most tvs that have pip will also have a swap button on the remote, it may be labeled with text, or it may just look like one screen overlaying another, press that one to swap between displays.
hope this helps,
trin
Nov 16, 2007 | Samsung PCJ522R 52" Rear Projection...
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
Turning off PIP on KP-61v45
I had this problem with a universal remote.I tried everything you can think of.Finally I got it.I hit the setup button on top of tv and the volue down button to start the demo.I dont know exactly how long it ran but after awhile I hit a button and screen was normal...Yeah
Mar 10, 2007 | Sony KP-61V45 61" Rear Projection...
Zenith MBR3447 Remote Control Logo
70 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
