Question about Sony Playstation 3 (PS3) Console
You turn it on and i beeps goes yellow then flashes red i got a new hard drive for it and it still does it
    President:
  • 1,139 Answers
Hi there, what you are referring to is called the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. As it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3.
Hope this helps and thank you for using FixYa
Posted on Sep 12, 2010
PS3 yellow lights won't turn on
You may have the yellow light of death. You get the yellow light of death when the playstation stays on too long or alot of use or it may taken some damage.
May 09, 2013 | Sony Playstation 3 (PS3) Console
When I turn on my PS3 it shows the green light first but then the light goes yellow and makes two beeping sounds. Then it goes back to red.
Your Hard Drive could be failing once it tries to read your HDD it will turn off if it is not working porperly. Try removing the hard drive and turn it on without it if you can get to the main screen without turn off then looks like it would be a bad hard drive.
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
When i turn on my PS3 it as it starts up a yellow light comes on
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Apr 16, 2010 | Sony PlayStation 3 40GB System
Shut off, light is flashin red, when you try to turn it on light goes green then yellow then flashes red again
this is a hard drive problem. if you remove the hard drive from the side of the consol (make sure its unplugged) clean the connections then replace it all it should work. if not you require a new hard drive im afraid
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
"yellow light of death" had my PS3 for 2 years now going on 3 and ive been very pleased and have had no issues until today. out of no where when i turn on the device it flashes yellow and turns right back...
Jan 11, 2010 | Sony Playstation 3 (PS3) Console
Certain DVDs cause my PS3 to shut off and blinking red light
If you think the **** player is causing the problem remove it and see if it turns on if not you could try another one and see if it works.
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
My hard drive has broken
Does the light flash red, or does it turn off completely?
If it flashes red, you've got an overheating problem. You either need to send it in to Sony, or a third party repair place.
If it turns off completely, you need a new power supply which you can attempt to repair yourself (they cost $30-$40 online) or again, send it in.
Sony charges about $150 USD plus shipping, third party repair places would most like charge $80-$100
With Sony though you usually don't get your system back, they send you a refurbished one (so all your data will be gone).
Usually these fixes don't last (from Sony either). Best bet is to just get someone backup the hard drive data and get your disc out, then buy a new system.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns off beeps twice but there is no yellow light only red!
Jul 16, 2009 | Sony PlayStation® 3 (60 GB) Console
Blinking red light
General hardware failure. Usually the red light means either bad power supply or bad hard drive.
You can start by pulling the hard drive out and then power on the system.
More than likely it's a power supply / motherboard issue, in which case you'll have to contact Sony for repair.
You can reach them @ 1-800-345-SONY
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
Want turn on
yeha me 2 today a woke up to a red flashing light on my ps3. I wondered wut it meant, searched it on google and found some pretty bad news. DEAD. after about 1/2 an hour of trying to turn it on i search a fix on google, but came up empty handed.
i decided that i would take the matter into my own hands. i took the hard drive out and turned it on, and to my amazement it work i dont know how, but it worked. i then wanted to play resistance fall of man. i booted up the game and boom it turned off beeped 3 times and the light flashed red onece again.
i took out the hard disk and booted it up again turned it off and put the hard disk back in. ive been playing ever since and it seems to be working fine. just thought that id give u guys a heads up, to help anyone else out there with the same problem. Hey, today a woke up to a red flashing light on my ps3. I wondered wut it meant, searched it on google and found some pretty bad news. DEAD. after about 1/2 an hour of trying to turn it on i search a fix on google, but came up empty handed.
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
12 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
