Question about Valco Baby TriMode EX Twin Stroller Arctic
In less than a week, I have had 2 flat tires on my Valco Twin TriMode EX. The tires are not over inflated. I now have the replacement tubes, but can't get the tires off of the plastic rims in order to install the new tubes, even with using the proper bicycle tire removers. Any ideas? I can change a flat on my bicycle in 4 minutes, but can't figure out this Valco tire.
  • Geez
    Geez Oct 23, 2013
    Giving birth to twins is easier than changing in inner tubes on a valco stroller. I did get it done, but it required a butter knife, flat head screwdriver and a bunch of cursing.
    Champion:
  • Valco Expert
  • 223 Answers
Hi, Take it to your local bike shop where they will do it for you. Regards Marie
Posted on Sep 22, 2010
The rear tires on my Everest & Jennings foldable wheelchair are very low in pressure. Both tires have the words "Inflate to 55 - 65 Pounds" clearly stamped on the sidewalls. However, there...
Your tire tubes may have been replaced with urethane foam inserts - these give a comfortable ride like air-filled tires but cannot go flat - would explain why you don't see a fill valve - these inserts fit inside the regular tire carcass.
If they are worn out, you'll need to replace them, process is same as replacing a tube.
Feb 20, 2011 | Everest & Jennings Advantage Manual...
How do you fold down the valco runabout trimode stroller? I bought a used model and I can get the top half to fold over but that's it. Can it fold over more compactly? I'd like to travel with it. Thanks!
hi!!
to fold the stroller yo need to:
1.fold the hood back up against the handle.
2.release the locking clamps at either side of the stroller.
3.simultaneously lift the secondary safety catch and swing the handle forward.
4.holding the frame at the rear, press down on the rear basket tube.
5.you also can lock the frame with the strap next to the frame.
here you have the manual, could be easy with de graphics!
http://valcobaby.com/uploads/tx_productcatalog/Tri-mode_2007_Instructions.pdf
hope to being helpful!!
(if so, dont forget to rate me!)
Sep 25, 2010 | Valco Runabout TriMode Single - Stone...
Baby stroller needs back wheel removed and tire replaced
look and see if there is a lil rubber plastic cover in the middle of the tire and press on it might be a release button to unlock and pull off the tire / thats how mine works. if that dont help u can just take the whole stroller to a bike shop and they will fix it for u
Mar 11, 2010 | Valco Twin Runabout ATS Jogger
Need a replacement innertube for a 12 1/2 x 2 1/4 inch stroller tire. where can I find one????
Hi.
You could try
http://www.amazon.com/12-1-2x2-1-Scooter-Inner-Tube/dp/B000U93ZEO
or
http://www.discountbicycles.co.uk/biz/product.php/5524/0/kenda_12_inch_schrader_valve_inner_tube
I have sucessfully used bicycleparts, amongst others, to fix my strollers thru the years... easier and much(!) cheaper... It works for me... give it a try!
Good Luck! :)
Cathy
Oct 21, 2009 | Valco Twin Runabout ATS Jogger
Replacement parts.
Many Valco Baby models are equipped with 12 inch tires. Just like a car or bike, punctures can occur. A 12 inch inner tube or bicycle tire repair kit would be all you need to seal the puncture. If need be, tubes can be purchased from your local retailer or contact them at (USA) 800 610 7850 or email info@valcobaby.com Tubes are not covered under warranty.
Aug 29, 2009 | Valco Twin Runabout - Blue Jogger Stroller
Tire maintenance
Check your tire air pressure at least once a week and before long trips. Be sure to use an accurate pressure gauge. -Check your air pressure when the tires are cold. The tires are cold when your motorcycle has been ridden less than a mile at moderate speed or after being stopped for three or more hours. -If you must add air when your tires are hot, add four pounds per square inch (4 psi)(28 kPa) above the recommended cold inflation pressure. Recheck the inflation pressure when the tire is cold. -Never release air from a hot tire in order to reach the recommended cold tire pressure. -Normal riding causes tires to run hotter and inflation pressure to increase. If you release air when your tires are hot, you may dangerously under inflate your tires. -If your tires lose more than two pounds per square inch (2 psi)(14 kPa) per month, the tire, the valve, or wheel may be damaged. Consult your local dealer for an inspection. -Use valve caps to keep valve cores clean, clear of debris and to help guard against air leakage.
Nov 10, 2008 | 2007 Suzuki GSX 1400
Flat tire--not fixable--is bubbling
I advise you try the shop where it came from for a replacement tube for it.
Failing that, 'phone the manufacturer to have one sent out.
Jun 11, 2008 | Baby Trend Expedition Double Jogger
Valco Baby  TriMode EX Twin Stroller  Arctic Logo
218 people viewed this question
Top Valco Baby Gear Experts
Andrew Taylor
Andrew Taylor
Dorel UK
Dorel UK
Are you a Valco Baby Gear Expert? Answer questions, earn points and help others
