How do you get a hp laptop computer to flip the right way
  • 32,281 Answers
UPSIDE DOWN DISPLAY This is caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Posted on Sep 12, 2010
How to fix a hp m7750n cooling fan
Checking the Fan Turn on your Pavilion and close the display panel.Flip your laptop upside-down and place it on a clean, flat surface. Shine a flashlight into the vent on the bottom of the computer and look to see if the cooling fan is spinning.
http://smallbusiness.chron.com/check-cooling-fan-hp-pavilion-laptop-55670.html
Dec 29, 2016 | HP Computers & Internet
HP LAPTOP G-60 630US KEYBOARD PART # 496771-001 HOW DO I TAKE THE OLD ONE OUT
Do it carefully..at your own risk..
HP 496771-001 Keyboard Repair and Replacement
Are you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick HP 496771-001 Keyboard repair tutorial with step-by-step instructions.
Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the HP 496771-001 Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the HP 496771-001 Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire HP laptop keyboard.
Final step: To insert the new HP 496771-001 Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the HP 496771-001 Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
Ron
Feb 12, 2011 | HP Computers & Internet
How do i flip my hp pavilion screen back right side up
Right click on the desktop and go to the graphics settings from the menu that appears. One of the options in there is to rotate the display 0, 90, 180 or 270 degrees. You can correct it from there
Nov 19, 2009 | HP Computers & Internet
Cannot get the flip camera to play videos or recognize the Flip shareware on my laptop. Working on Windows XP
You may just have a simple problem with the device 'Drive Letter' allocation.
When you plug in the Flip into your USB your computer will assign the device a drive letter, if this letter is used already say for a network or mapped drive or other USB connection the Flip will not be recognized.
To check and see if that's the problem, plug in the Flip and go to your desktop
(right click) on My Computer / Manage / Disk Management
In that list see if the device is listed (you'll know by the name or storage size of the device) If it's there right click and 'change drive letter' to an unused drive letter.
Hopefully this will fix your problem.
Nov 02, 2009 | Pure Digital Flip Video Ultra Camcorder
Need to change battery
http://h10032.www1.hp.com/ctg/Manual/c00326469.pdf
This is a link to the owner's manual. It shows pictures of the laptop and where the battery is located. Probably easy to find a replacement battery on ebay.com or elsewhere. The battery should have a number on it for reordering or you can find one at www.hp.com
Oct 01, 2009 | HP Compaq Presario 2200 Notebook
How do I open the HP Pavilion ze 4300 to replace the powerjack
All screws need to be removed off the back of the computer then you need to flip the computer over and then remove the plate right above the keyboard and remove the screws there. Once that is done you will be able to get into the motherboard
Feb 08, 2009 | HP Pavilion ze4300 Notebook
How do I orientate my screen so that i do not have to flip the computer around after i switch into tablet mode?
Press the button in the lower right corner of the screen marked with two arrows following each other.
Moreover, you can use Tablet Properties to set the orientation you desire as default when you flip to tablet mode.
Jan 13, 2009 | HP Pavilion tx2500z Notebook
Audio driver
there is a chance that the driver u have is not the right one since hp was so nice to make so many ver. of the v2000 for different retailers to see which u have flip your laptop over and look on the sticker for a service tag# right below the operating system sticker go to www.hp.com and in the drivers section enter that number in sted of the v2000 that number is your actural ver. of the v2000 and u will be able to fid the right drivers
Jun 26, 2008 | HP Compaq Presario V2000 Notebook
HDMI connection on HP Pavilion dv9000
try going to windows mobility center & click connect displays
Feb 03, 2008 | HP Pavilion dv9000z Notebook
Hp tc4400 lcd keep rotating
I had the same problem and no help from HP Tech support. They had system for week and climed that nothing wrong. When I got it back from HP and it still rotates constantly with no reason. Then I deside to replace laptop keyboard and to my surprise this took a care of BIG problem. No screen rotation I have ever experienced.
By replacin dirty or defective keyboard I solved this problem.
Art.
Nov 14, 2007 | Tablets & eReaders
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
