Question about LG FLATRON L1950B-SF 19" LCD Monitor
Hi, I have an LG monitor Flatron L1950B and there has currently been small blue lines apprearing at the top of the monitor. They are causing sight problems as they are blocking more and more of the text and screen. There are even giant blocks about 1cm by 1 cm that block the screen. I think they are stuck pixels but they are alot of them please help me fix this. :)
4 Suggested Answers
anjana03
  • 361 Answers
SOURCE: LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
Posted on Jun 15, 2009
freetek
  • 5568 Answers
SOURCE: LG f700b raster problem
If the lines are slanted, you are seeing 'retrace' of the horizontal sweep. The distortion at the top is probably caused by a failing electrolytic capacitor in the vertical deflection circuit or in the power supply filtering for that circuit.
If you want to try to find this problem on your own, use great caution! There are exposed parts that can carry very nasty if not fatal voltages.
Go to any electronics parts source and buy two cans of 'freeze spray.' Expect to pay $4-5 dollars each for them. Using this on a 'live' monitor makes it still a little more hazardous since the cooled parts will form frost that may be conductive and I recommend keeping one hand behind your back so even if you touch something 'hot' you won't have currents passing through your heart.
With the rear case removed, you might drape a clean towel over the guts to let it warm up as it would if cased. When you notice the distortion going away, remove the towel and start spraying short bursts at the cylindrical parts, mostly those of 'medium' size ranging from ~ 3/4 to 1 1/2 inches in height and 1/2 to 3/4" in diameter. These are the parts with values most likely to be failing.
If you can identify the power transformer, a largish block, mostly black, check those capacitors first. You will need a mirror to watch the screen for the worsening of the distortion again and be patient; the parts you are cooling have some thermal mass so the effect is not immediate.
If you find one that seems to affect the picture, then, if you have one, direct a hair dryer (blower type) at that area to see if you can recreate the problem several times.
If you can isolate one specific part, note the value of it; it will have several printed items: - Capacitance - this will be such as this: '100 uF' - Voltage - '63V' - Polarity - this will be marked with a '+' and maybe a minus on the other leg. This is important! Any new part must be installed with the correct polarity if any is shown and it will be present on this type of part.
These parts are very inexpensive so if you cannot decide which one is at fault, replace all of them in that area; they cost from 20 cents to a buck. If you have no local electronic parts store (Radio Shack doesn't have much any more) you can order them from Mouser Electronics. Mouser has NO minimum charge and adds only real postage/shipping charges. You'll find them at mouser.com
If you decide to go this route, you will have to acquire and learn to solder with a soldering iron. Or if you have a friend who is an amateur radio operator, they will probably do this for you.
Removing the board from the bottom of the case is pretty easy, just make sure the monitor has been OFF for a while otherwise removing the thick cable from the CRT will be a really memorable experience!
Looking at the bottom of the board, note the look of the other solder joints there and do your best to duplicate them when installing the new part(s), bad solder joints can make your repair futile.
Or, you can stuff the wole thing in an envelope and send it to me ;-)
If you have been happy with this unit, it is worth the repair, since LCD monitors are often dead soon after the warranty has passed on.
Good luck
Posted on Jul 26, 2009
  • 452 Answers
SOURCE: My LG Flatron L1520B monitor "Locked/Unlocked"
press the power button for 1 mn and release it if still the same problem change your inverter board.
Posted on Oct 28, 2010
Cant display images just blinking
is the power light good.
is the OSD working?
Sep 27, 2013 | LG FLATRON L1950B-SF 19" LCD Monitor
Omi have lg flatron 1941s lcd monitor its OSD locked how to solve it
i have a problem with my lcd a small area is permanently black a scratch like lines less than 4 mm X3 mm size
Sep 17, 2010 | LG Flatron L1515S 15" LCD Monitor
LG Flatron L193ST. Relatively old model. The monitor screen stays dark upon connecting with a power socket and the power LED blinks rapidly in a yellowish amber colour. A quiet pulsating sound emits from...
L193ST common problem!! solution is only by replacing 2 capacitors 470uf 25v located on the power supply pcb inside the lcd they are neer the long cable connector
remove the 8 screws from the lcd back panel including the holder screws,
use a thin metal stick like a knife and insert it between the back pannel and the front black panel but slowly remove the black panel not to scratch it
remove the metal protection panel 4 screws
the power pcb becomes visible
remove all connected plugs and the 3 screws
desolder the 2 capacitors and replace them
assemble back your lcd and enjoy
30min time of work 5$ cost
Sep 06, 2010 | LG FLATRON L1950B-SF 19" LCD Monitor
I have a LG flatron W2243S and after 14h of use a blue line appeared across the screen what to do now?
The line appeared because the commands to the pixels in that line got damaged. The only thing you can do is to take it apart and reseat the connectors to the lcd panel. If it's the same then the fault is in the panel itself and this is unfixable. Either use it as is or junk it.
Aug 19, 2010 | LG 22" FLATRON LCD Monitor
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
When i turn on my flatron 22 inch monitor the blue power button comes on for a second then goes out,it will not stay on.
HI,
your monitor is not working properly, bcoz monitor data cable no connected properly into the System or any internal problem in your monitor.
Thanks
Aug 15, 2009 | LG 22" FLATRON LCD Monitor
LG Flatron 776FM mic is not working using XP Prof. SP3
it is the one that is blue in color and has an L on it for low pressure. The vapor line is also called the suction line. If your confused, then choose the larger of the two lines near the accumulator.
Jun 13, 2009 | LG Flatron 776FM 17" CRT Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
LG FLATRON  L1950B-SF 19" LCD Monitor Logo
42 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
