I have an Acer AL1916W A monitor. I had my system running when we suffered 3 power outages in a row. Now, my monitor will power up, but I only get a black screen and the power button pulsates from green to orange. I didn't get a manual with this computer so I don't know how to open it up either. From reading the other questions, it sounds like the capacitators are bad. I don't know how to replace them if that is the problem. Please help!!!!!!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 144 Answers
First make sure that the OS boots, u can check this with another monitor since it is rare case that a monitor goes down.
If the OS boots then try checking the power cable from Monitor to CPU.
If it doesn't work take the monitor to a hardware service centre.
Posted on Sep 12, 2010
My acer 19" monitor has no signal what should i do?
  1. check whether the signal cable properly connected to the vga port or not ?
2.listen the single beep from PC
3.try monitor on another PC . if persists , then the fault lies in the monitor . if not then the fault is in the CPU
thank you.
4.if no beep from CPU then disconnect RAM . listen contineus beep . if heard , then the RAM is faulty , replace it .
Jul 23, 2010 | Acer AL1916W 19" LCD Monitor
Acer monitor suffers power outage; screen shows very dark colors
There is no key to use for opening the case. Please see the service manuals here:
http://elektrotanya.com/?q=showresult&megnev=ACER megnev2% 20 & = & Category = & AL1916 kat2 = all
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 07, 2010 | Acer AL1916W 19" LCD Monitor
How do you hook up sound to the computer. I have
The ACER AL1916W does not have built-in speakers, you need to get powered speaker system for your PC.
This is the spec of the AL1916W: http://reviews.cnet.com/lcd-monitors/acer-al1916w-lcd-display/4507-3174_7-31652355.html?tag=mncolBtm;rnav
Mar 30, 2010 | Acer AL1916W 19" LCD Monitor
The power went out twice in a one hour period a couple of days ago. After the second outage, my monitor would not come back on. Unfortunately, I had removed it from the surge protector to plug something...
1) Have you checked the fuse in the mains plug ?
2) There may also be a secondary fuse, inside the monitor (don't as me how to dismantle it, all I know is carefully) on the main cct board near to the power in socket.
Mar 14, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Need a manual for this monitor
Kindly click this link and click on the PDF file to download the manual:
http://safemanuals.com/user-guide-instructions-owner-manual/ACER/AL1916W-_E
May 01, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor '' no power''
I'm having the same problem and it turns out to be the main board.This Service guide is for Version 1.0 but turned out to be helpful
http://www.abcelectronique.com/forum/attachment.php?attachmentid=12292
Feb 28, 2008 | Acer AL1916W 19" LCD Monitor
No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Jan 05, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
