Question about Ovens
Changing stove from gas to lp do we need to open top of stove to do this?
  • 494 Answers
Only if it is an open burner stove. Sealed burner stoves are converted without removing the top. Which do you have? Your owner's manual shows how to convert it. If you're missing the manual, tell us your stove make & exact model # and we'll see if it's available online to download. Douglas
Posted on Sep 12, 2010
Convert dfg200 from gas to lp
being this is a commercial oven you will nee3d to go to a commercial parts purveyor to get the conversion parts,on residential units the orfices are included with the range when new for conversion at any time,the gas orfices need to be changed on the top burners,then the orfice spuds in the oven bake and broil units need to be turned down onto the orfice for conversion,your commercial parts person will have the steps with the conversion kit to do the change-over
Nov 24, 2012 | Blodgett DFG200 Stainless Steel Gas Double...
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The stove and cook tops send all the pots black with soot
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 28, 2011 | Ovens
Need to kmow location to change orfis to change from n gas to lp
when changing a stove or oven from natural to lp the orifices would be inside the burners or under the upper deck of the oven also you would also need to flip the cap around on the gas regulator as well if you have a model number i might be able to show you a schematic of how to locate your orifices on most units the upper deck flips upwards in order to provide you access under the burners this is where the orifices are usually access As a matter of fact I have 9 today that I will be personally switching from propane to natural not only amanas either fun day for me planned if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to continue helping people in similar situations in the future Thanks again Rick
Apr 29, 2011 | Amana Ovens
I will soon need to convert a 1993(?) CALORIC Kitchen Range back to Natural Gas from LP. When I installed it, NG was not available, so the propane company guys converted it to LP. I was not here to learn...
First check the regulator valve on the back of the stove. Chances are it is a dual purpose valve and once you are ready to do the converstion.. you simply will move the lever or change the setting from LP to NAT.(obvisouly before proceeding you need to have the fuel supply turned off to the appliance)
Next check under the range lid or on the back of the stove for the spare NATural gas orifices.. when they changed it out for you there were two scenarios.. the range (most do) came with a set of LP orifices..and they simply changed these out on each burner supply including brolier/oven. (orifices are interchangeable nozzles that are threaded into the supply gas burner)
If they had to swap out the regulator chances are they would have given you the one that came with your stove.. However I am fairly sure the regulator is a dual purpose and you simply need to change the setting from LP to NAT.
DO NOT DO THIS WITHOUT CHANGING OUT THE ORIFICES FIRST.
If you cannot locate the spare orifices/spud/nozzles (they are called all of these) on the stove itself you will need to buy a set. A good appliance parts store will be able to help you with these.. again.. you will need one for each burner/burner supply.
If you can locate the range manual it will have instructions on how to do this.
Chances are your Natural Gas company will be able to help you with this.. especially if the regulator is dual purpose.. even if you can't find the orifices they are inexpensive.. fairly standard and easy to acquire. Usually just called a "conversion kit".. it will just consist of four or five small threaded 5/16 brass nozzles/orifices.
The installation is pretty straightforward. Again..a good appliance parts store may recommend a service company...and if your not familiar with diy repairs on a gas appliance.. a 50 to 100 dollar service call is well worth the money.
Best of luck to you!
Apr 11, 2011 | Ovens
DCS 5 burner 30" oven makes loud noises as if starved for fuel
Hi; Is the oven run with LP or NAT gas. Sounds like a regulator problem not letting enough gas through. Also is this a comercial unit. If so when was the last time all burners and pilot orafices were cleaned out. The burner tubes have a air vent cut into the burner at the orafice. Make sure no debris have covered these airways.And lastly how old are the thermocouples and are they secure to the gas valves and have a good pilot flame on them...
alpharome416
Feb 23, 2010 | Ovens
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
How do I adjust the flame on my Frigidaire model FGS383BADK stove?
its going to be listed in the installation manual ,not use and care, youre going to need to convert oven for lp gas. i would call the manufacture with the modelk number and ask for hte coorect conversin kit, for such a thing
Nov 03, 2008 | Frigidaire Ovens
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Ovens Logo
100 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
