Question about Gateway FPD2275W LCD Monitor
Right in the middle of using the computer, the monitor went black. I know it is plugged in because the blue on the bottom right is on. There is just no video.
  • 11,361 Answers
Common failure in this monitor is bad DC filter caps, you can also more problem than just bad caps in the inverter circuits.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Be warn that it is real difficult to take apart and you can easily damage the ribbon cable attached to the front bezel.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 13, 2010
Acer gd235hz 23.6 lcd monitor is blank on the right side only the left side of the screen shows pictures
It sounds like the monitor is broken. You should probably just buy a new one. If you haven't already, try checking the cable connections to the pc. Outside of that, there's not much you can do. Hopefully you still have a warranty on it and cant have it fixed.
Oct 18, 2017 | Acer Gd235hz 23.6" Lcd Monitor - Black
Dual screen wont work
Kevin,
1) You cannot plug a monitor into the VGA connector, on the back of the desktop computer, AND plug a second monitor into a DVI connector, on the back of a desktop computer.
In otherwords you can only plug ONE monitor into the motherboard.
[ The I/O area on the back of the desktop computer, is the Input/Output area. This rectangular area has connections for Input devices, and Output devices.
Examples such as a Mouse, Keyboard, (INPUT), VGA devices, (VGA monitor - Output), USB devices, audio devices, (Speakers - Output. Microphone is an Input device), and so on.
The I/O area has a rectangular metal shield. (Thin metal plate)
Connecting a device in the I/O area, is connecting it directly to the motherboard.
Example of a VGA connector, and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(There are several variations of DVI connectors.
Scroll down ]
To use dual monitors you need a graphics card also.
Graphics card with a VGA connector, or DVI connector. (Or both)
Monitor with VGA cable, plugs into the I/O area on the back of the desktop computer. (Plugs into the motherboard's graphic chipset)
The second monitor plugs into the graphics card's DVI connector, or VGA connector.
[ Just an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1416091&CatId=3669
On the image of the graphics card on the left;
Go under it to the subheading - + 11 larger images and views.
There are 7 views shown. One is the carton the graphics card comes in. (View 2 from the left)
Going from the left side, count over to the 5th view. Left-click on the 5th view. Shows you the 'business end' of the graphics card.
Starting at the left side it is the HDMI connector, then VGA connector, then DVI connector.
Note*
YES, you can plug a VGA monitor, AND a DVI monitor, into this type of graphics card, and have Dual monitors ]
FIRST:
Computer on, Windows running; Put the Installation disk (CD) in the optical drive's tray. (CD/DVD drive)
Load ALL software.
Drivers, and 'Control Panel'.
Graphics card software loaded, close all windows, go back to your desktop screen. Turn the computer off normally.
Unplug the computer from power. Open the computer case.
FOLLOW Anti-Static Precautions.
(Don't know Anti-Static Precautions? Post back in a Comment)
Physically install the graphics card. Close the computer case.
Plug the VGA cable of the Primary monitor, into the VGA connector in the I/O area, on the back of the desktop computer.
Now plug the DVI cable of the Secondary monitor, into the DVI connector on the graphics card.
(The main monitor you use is the Primary monitor. The second monitor you are going to add, is the Secondary monitor )
Plug the computer into power. Both monitors plugged into power, turn them BOTH on.
Turn the computer on.
When Windows loads you will see a display on the Primary monitor.
Your desktop screen.
Now Right-click on an empty area of your desktop screen.
In the list at the bottom, Left-click on - Properties.
In the Display Properties window that comes up, left-click on the -
Settings tab.
You will see two rectangular icons. 1 and 2.
1 is the Primary monitor. 2 is the Secondary monitor.
Left-click on the Secondary monitor icon.
Go down towards the bottom/middle on the left.
Left-click in the empty square to the left of -
Extend my Windows desktop onto this monitor
Go down to the bottom Right. Left-click on Apply.
Go down to the bottom Left. Left-click on OK.
Your desktop screen will now be on the secondary monitor.
When you open your internet browser, (Yahoo, or Google, or MSN, or Mozilla Firefox, etc), you have to DRAG the screen onto the secondary monitor.
(Let's use Yahoo for an example. Yahoo will be on your Primary monitor.
You need to drag Yahoo onto the Secondary monitor)
Which direction you drag, is up to which direction the two monitors are sitting, on your computer desk.
The way the monitors are sitting in Display Properties; the Primary monitor is on the Left. ( 1 )
The Secondary monitor ( 2 ) is on the Right.
This is the way the two monitors should sit on your computer desk.
(There is a way to switch them around, however)
On your Primary monitor, (Still using Yahoo as an example), go to the RIGHT side. See the blue frame going around the screen?
When you bring the mouse cursor ON the blue frame, it turns into a Double-Sided arrow.
It is difficult at first to keep the cursor as a double-sided arrow.
Move too far to the right, it turns into the usual pointed cursor.
Move too far to the left, and it turns into the usual pointed cursor.
have to keep it on the blue frame.
WHILE the mouse cursor is a Double-Sided arrow, left-click, and hold the left mouse button down. Now drag the screen to the Right.
(Move your mouse to the right)
Keep dragging until the Yahoo browser is on both monitors.
Different size monitors? The display will not be the same size, on both monitors.
[ I use an HP 2009m, 20-inch widescreen monitor, as a Primary monitor, and an RCA EN-V, 26 inch HDTV, as a Secondary monitor.
I have my desktop on the Primary monitor, and FixYa, (Firefox browser), on the Secondary monitor, right now ]
If this is not your problem please state in a Comment.
Also state additional questions in a Comment.
Regards,
joecoolvette
May 10, 2012 | Computers & Internet
Can u uninstall emachines then reinstall so that the colors are right
1) Right-click on an empty area of your desktop screen.
2) Left-click on Properties at the bottom of the list.
3) Left-click on the Settings tab.
4) In the middle on the right side; What does it state for Color quality?
It should state - Highest (32 bit)
If not left-click on the blue down arrow to the right of this box.
(Color quality box)
Left-click on Highest (32 bit)
Now go below to the right, and click on Apply.
Then go to the bottom left, and click on OK.
Still no change?
Go to your monitor, and monitor settings. See if the colors are set right.
Still no?
If the monitor is a flat LCD screen, see if there is another KNOWN to be good monitor cable, (From another computer?), to use for a test.
If you are using an older CRT monitor, it may be at the end of it's 'Life Cycle'.
(Looks like a small TV)
Regards,
joecoolvette
Jan 20, 2012 | E-Machines eMachines Desktop PC
Can i connect two monitors to a nvidia geforce 315 card so as too use two monitors
hi,
yes the 315 desktop card does have multi monitor support. you may however need an adapter for one monitor as it only has one dvi ,one hdmi and one vga.
so you can hook up any 2 as a combination but they have different plug configurations to do this
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Sep 16, 2011 | Computers & Internet
-1985 Porsche 911 took off door panels pulled the wires off the power window switches did not label them and now i don't know what color goes to what # connector on the switch
hello there
As you are looking at the switch ,the single connector should be on the top.
Top single conn. is linked with bottom left(red wire)
Bottom right -brown
middle left is blue with black strip
middle right blue with white stripe.
Sometimes this middle wires should be switched(left-right position), the are for window doing up and down.
Same goes for the front switch for pass window.
i hope this helps
Ivan
trubka
Nov 29, 2010 | Porsche 911 Cars & Trucks
The bottom of my screen is black and blue starting solid on bottom and sides for about an inch give or take then gradually becomes spotted balck with blue background and has a pink line running vertically...
I suggest either trying another monitor on the computer with this problem or plugging the monitor into another computer.
That will isolate the fault to either the computer or the monitor.
Nov 15, 2017 | ViewSonic VX910 19" LCD Monitor
I have a Classic Coffee Concepts GB360 maker that needs switches
I have the same coffee maker which has a heater problem but the wiring is intact. The switches are wired like this:
Right Rear Warmer Switch: Top - White from other two switches
Middle: Black from other switches
Bottom: Red
Right Front Warmer Switch: Top: White shared with other two switches.
Middle: Black with connector to Black on other switches
Bottom: Blue
Lower Front Warmer Switch: Top: White from other switches and connector to white from inside.
Middle: Black and Purple together
Bottom: Black from inside and Purple from inside on a connector.
Jul 07, 2010 | Classic Coffee Concepts SSU50 Stainless...
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Monitor
That's better.
Yep, 95% chance it is the power inverter problem.
If you don't remember the screen having a pink tint or flickering for a while or being dark at the middle top or bottom before it went, then your bulbs should be okay.
It will need at least all the capacitors replaced.
I fix many of these types on ebay.
bammbammfran
Oct 15, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
21 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
