FixYa.com
Tags:
Intel D845EPI  Motherboard
Want to improve mt RAm size
posted by sanbme on May 14, 2008
I have Intel D845GVSR/D845EPI model mother moard, with 128mb RAM size. What is the maximum RAM size i can increase.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 14, 2008
FixYa! (100)
map9966
Rank:Guru Guru
Rating: 88%, 1056 votes
Hi sanbme, you're Intel board can run 2x1GB of PC2700 / DDR333MHz Double sided memory. Two 2.5 V 184-pin DDR DIMM sockets with gold-plated contacts.
Serial Presence Detect (SPD). You can see Intel's web site breakdown of supported memory by clicking on this link.
http://support.intel.com/support/motherboards/desktop/d845epi/sb/cs-017166.htm
Scroll down to, "The following table lists the supported DDR DIMM configurations". Here you'll see the chart.
This next link supports the Intel D845GVSR motherboard for memory.
http://www.1stchoicememory.com/catalog/configurator.asp?b=INTEL&m=1955&p=C019551757
You can also got to this link & Crucial will scan you're system & make suggestions. http://www.crucial.com/store/drammemory.aspx
Enjoy!
Still have questions? Feel free to ask.
Mike
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
which mother board to go with
i'm buying 2 visiontek radeon... Answer This...
Motherboards
fredy
nesecito el driver del sonido... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Motherboards
je veut des instrustion
instrustion pour le produit:... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
