Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
My bissell vaccum doesnt work even though i've replaced the belt but when ever i turn it on i get this rubber smell...can anyone tell me
  • 377 Answers
Sounds like the beater brush that the belt controls is frozen in place and needs to be cleaned. Remove the brush and clean any debris that you find on it AND at either end. The end pcs are used to hold the ends of the brush stationary while it spins via the belt. When you get the brush off, spray both end pcs with a bit of WD40 and work by hand until they spin freely. This should solve your problem.
Posted on Sep 12, 2010
When i use the vaccum, it smells like burning rubber. I know this is probably a belt issue, but will a replacement belt solve the problem? If so what belt and where can i find it?
I would first check to see that the brush is not stuck. Remove any hair, or foreign objects that could possibly stop the brush from rotating. Some machines have latches to remove the plate for access to the belt and others have a couple of screws. Yes I suggest that you replace the belt. Good Luck
Jan 06, 2011 | Bissell Lift-Off(R) Revolution(R) Turbo...
Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Mar 24, 2010 | Miele S318 Bagged Canister Vacuum
Vaccum cleaner belt change
If you've put a new belt on and you still are getting a rubber smell, then odds are that your agitator (the rotating brush) is not turning freely, and that means either (a) you need to remove the end caps and remove any hair / debris that is under those end caps, or (2) the bearing(s) of the agitator are bad. Depending on the model of the Sharp (which was not provided), you may be able to order just the defective bearings and replace them (or take the agitator to a vacuum shop to have them do it), or you can (or may need to) order the agitator assembly complete.
May 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Not working
The bissell shampooers use belts t run the pump and the beater bar. if the master beltbroke which is the one that controls the pump and beater bar then yes the machine will not dispense water or turn the beater bar. it will have to be replaced *the belt that is*
Nov 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
I checked the belt and it has not broken, but when I start to vaccum the spinning head stops, and I start to smell a rubber smell...Do you think I need to replace the belt, I did get some string caught in...
Yes you do need to replace the belt they stretch out. Think of a belt like a big rubber band if you were to stretch it out and hold a lighter to it the rubber band would stay stretched out. That is the same thing that happens when you get it caught on string or an area rug the brush stops but the little metal shaft keeps spinning creating heat and stretching the belt. Visit www.stevessewandvac.com for belts, bags or any other vacuum need.
Aug 13, 2008 | Bissell Vacuums
Bissell Lift Off Broken Belt and Brush Roller
I had the same problem. I found that the brush actually melted to the end cap (the one with the square/ovalish end). I was able to pull it off with some force and applied some WD-40, but that only worked for one more use. The brush has again melted to the end cap and it is too deformed to try and fix. I suppose I will have to search for a new brush, but this model obviously has some innate flaws.
Feb 14, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Lift-Off(R) Revolution(R) Turbo Upright.
If you have a rubber smell, then the belt is slipping, does the brush roll turn freely while holding the ends? If not then replace it, part #2036619, if it is ok, then the belt has strectched and is slipping under load, part # 2106679, Style 8.
Jan 20, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Dec 31, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
77 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
