Question about Toro Garden
How to time the 12H802 modle lawn mower - Toro Garden
  • 3,740 Answers
This is the B & S 6 HP engine. There are multiple versions of this engine:
12H802-2682-B1
12H802-1922-E1
12H802-3172-E1
12H802-1752-A1
and several others.
The timing is fixed. It is not changeable. Timing can change if the flywheel key is partially sheared because the position of the magnetos' flywheel magnet is rotated forward or back from it's usual position. That is the only way the timing can change.
Now if we are talking valve cam timing. Align the dot holes on the crankshaft and cam shaft gear. The valves should be closed with piston at top of the cylinder.
Thanks for choosing FixYa.
Kelly
Posted on Sep 12, 2010
My briggs and stratton Model 12H802 engine is hard starting
hard starting on small four stroke engines is often related to valve clearances closing up due to normal wear. Its not a hard job if your a mechanically inclined. Few small tools, feeler gauge and new gasket for the valve cover. maybe a 30-40 min job .....many youtube videos.
Aug 14, 2014 | Omega Rear Drive Wheel Snapper Mowers
12h802 2684 b1
did you mount the coil and set the air gap correctly there is a cylinder side marked on the coil if all that is correct check it by unplugging the ground wire and try
Jun 06, 2013 | Garden
Engine shuts down after running for awhile
Could be a bad coil. I had a Cub Cadet that would shut off when it warmed up. After it cooled, it would start up just fine. I ordered a replacement coil from a local dealer and replaced it. It works fine now. Unless you are comfortable with mechanical repairs, you might want to take this to a qualified small engine repair shop.
Jun 22, 2012 | Garden
Adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
Apr 26, 2012 | Briggs & Stratton Garden
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
I recently got a green Craftsman with yellow writing "Craftsman" and ("22" Mulcher") I didn't know where to look for the model number. I found a family "YBSXS.1901VC" then "274466" it also said not legal...
You need to take the mower into a SEARS authorized store and have them show you the code meanings. Craftsman has changed a lot of their codes so for the first time this is the only way.
Sep 11, 2010 | Craftsman Garden
I bought a Powlan Pro modle # PR6Y22CHB 3 yers back,having some problem now.I went to their webside but i could not get any modle no that match my modle no.I need to order some parts.What can i do now ?...
Electrolux Parts, Electrolux Home Products-OrderTree.com ... Electrolux Parts. Electrolux is a leading producer of home appliances and equipment.
you need to try ordertree.com
your poulan was attatched to electrolux at the time it was made
your mod# doesnt come up so when you go to this site find electrolux and enter mod#pr6y33chb
and see if this looks like your mower plus you can order from this site also if you need to.
Jun 07, 2009 | Poulan Pro " Pro" Self Propelled Mower
Lawn mower carburetor
It is a tecumseh , remove screws from intake pipe to block
mark holes for linkage don't stretch springs.
Remove bottom bowl nut it is reg thread so turn counter clock wise . parts needed 631021b bowl gasket and needle and seat,
36786 intake gasket,
632547 2 o rings,
36905 air filter .
Use a can of carb cleaner auto zone spray all holes even the one
on the bowl nut , take out center plastic main nozzle out put on the new o rings put back in , some time the nozzle will brake part 3 640019 .
Remove seat can use comp air or make tool out of paper clip don't
scratch the side when pulling out
Good luck
Feb 02, 2009 | Oregon Scientific Oregon Fusion Blade For...
Garden Logo
379 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
