Question about GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop
I have a GE JGP963 gas cooktop. When you turn the knob the igniters come on all the burners. The spark is good. This works on all knobs. But what happens is that it will not light. It appears there is no gas flow? When you turn any burner on the sparks turn on but it wont light, I try lighting it while its clicking with a lighter and it still wont light. If you turn any of the knobs past the ingition area to the on area and then back to ignition it will light. So it appears the gas is not coming on while it is in the ignition area. It must be something with the gas? It does not appear to be spark problem. Please help I cant figure it out.
  • pauljr672 Sep 12, 2010
    There is no problem with the gas supply I checked that. When I turn the knob all the way on the gas flows no problem. I can light it with a lighter. It is only when it starts that the gas flow does not happen. If I turn it to lite it takes almost 30 seconds for the gas to start flowing then it will start. I tried to hold a lighter to it during that time and it would not light. The gas does not flow during this period. Is there a switch or something that activates the gas to start coming out? It finally does come on and the flames are great. Great flow. Its just slow to start flowing the gas. Maybe some type of regulator?
  • 494 Answers
Hello, Is this a new unit? Is it still under warranty? Has it been recently worked on or converted to another type gas? I'd call the manufacturer (or the company that installed it) and have them send out a qualified technician to fix it. Are the burner flames a nice even blue color? Can you adjust the flames from high to simmer without them going out. If it was converted to another gas type, it's possible the wrong size orifices were put in or possibly that it needs to be converted because it is a natural gas unit that should be changed to propane, or vice-versa. Also be sure the appliance regulator was switched over to the correct type of gas. These are just a few ideas that come to mind. Let me know if any of these apply. Douglas
Posted on Sep 12, 2010
    Douglas thank you. The stove is 8 years old. Has not been worked on at all. Just happened overnight? Runs on natural gas. The flames look uniform and blue. Yes you can adjust the flames from high to simmer no problem.
  • Douglas Jensen Sep 12, 2010
    OK, if it's an older stove and it's the same problem with all the burners, maybe it's a gas pressure problem. Are you having any issues with your other gas appliances? if not, this appliance has it's own appliance regulator under the top, so the stovetop may have a faulty one.
    I am assuming nothing was spilled on the stovetop prior to this strange occurrence. Douglas
I have a GE 36" Profile Gas Cooktop JGP963 and when i light one of the burners, it trips the GFCI , main breaker and a little fire ball comes from under the knob. what could cause this?
IT SOUNDS LIKE YOU HAVE A SHORT IN THE IGNITER. YOUR COOKTOP SHOULD BE ON A DEDICATED CIRCUIT AND NOT A GFCI. YOU MIGHT HAVE TWO CIRCUITS TIED INTO THE SAME RUN. POPPING THE GFCI AND THE MAIN BREAKER IS SUSPECT. THE GFCI SHOULD SHUT DOWN THE CIRCUIT WITHOUT POPPING THE MAIN. THIS IS PROBLEM THAT SHOULD BE LOOKED AT BY AND ELECTRITION.
Apr 04, 2013 | GE 36 in. Profile JGP963 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
The igniter doesn't work at all. If I turn any knob to the ignite setting, you can hear the gas coming out but there is no ticking sound, and therefore no ignition. Can I fix this myself?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 03, 2010 | GE 36 in. JGP628 Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop Logo
319 people viewed this question
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
